For Sale ** SOLD: 1996 Lexus LX450 near Raleigh, NC **
Pittsboro, NC
White LX450 with updated suspension (stock height OME) and tires and many other things.
Also a LOT of service items have been done on this one in the last 3K miles.
$8K price
Located in Pittsboro, NC - - just west of Raleigh.
Will share additional pics via Google shared folder upon PM. Thanks!
Just below 219K miles
  • Very little to no rust underneath
  • New 305/70R16 BFG AT KO2 Tires (@217K miles) - new full sized spare underneath
  • OME 861/862 Stock Height Suspension (@217K miles)
  • New Radiator by Mt Airy Toyota, pro install, new hoses. New front brakes/rotors at that time
  • WeatherTech floor mats front/cargo
  • New front/rear struts for hatch/hood
  • Repair Console Lid - New Leather
  • Front axle does not leak through birfs, grease in good condition
  • Updated mechanical seats - very comfortable - no more broken gears
  • Full PM and baseline (~215 to 218K) - Lots of new hoses, valve cover/disti gasket/rings
    • Xfer Case, Diffs Synthetics at 215K miles
    • PCV Bypass filter
    • Charcoal canister swap to GM - new lines
    • Sandblast/ Paint Valve Cover
    • Rear Brakes Pads 04466-60020
    • Heater valve 87240-60170
    • Valve Cover gasket
    • Distributor O ring 90099-14118
    • 1/2 moons 11183-50010
    • Spark plug gaskets 11193-15010
    • Sew spark plugs 90919-01176
    • Inspect plug wires. Resistance test ok on all 6 wires.
    • Check disti for oil and clean
    • Check Tie Rod Ends or other steering issues. Tie rods test OK.
    • Repack bearing, tighten wheel bearing nut.
    • Window Runs 68141-60010. 68151-60010 68142-60011. 68152-60011
    • Door Locks clean
    • Repair Mirror wobbling (Driver side, Passenger is ok)
    • Clean Throttle body, vacuum ports
    • Clean Carbon from EGR intake runners
    • Check All Vacuum lines/Replace as needed
    • Replace charcoal canister rubber hose 77754-60180
    • Replace EGR hose 26595-66010
    • Replace water bypass hose 16264-66021
    • Fix D Light
    • Replace power Antenna w/manual 86300-60030
  • Most recent services at Midstate Toyota:
    • New AC compressor with new belts, seals o-rings, etc.
    • ATF drain and fill
The Bad:
  • White paint is discolored in spots - rough in spots - small dent on passenger right side (hard to see in pics)
  • Couple dents on top - like three one like a tennis ball bumped it the others are like a golf ball did. None are "deep" or noticeable from the road
  • Small crack in driver side of the windshield in the last inch or so of the bottom corner- does not leak
  • Steering column adjustment is a little weird, but once locked in place it is like others
  • General condition of carpet is "good" not great
  • Driver rear door has to be manually locked/unlocked
  • 2nd and 3rd Row seat leather is good with no rips, but not perfect
  • Transmission oil pan has had some rough-looking welding done to it, but looks to be very strong - no leaks
  • Some weeping of oil around transfer case. Some left over oil from Valve Covers and Disti on the drive train.
  • VERY light leak from the upper oil pain that does not result in active leaks onto ground below. (shown in pics on shared drive)
  • I have detailed pics of this stuff - send me your email and I will send you the Google Pics Shared folder with lots of pics
Shared file invite sent, @LumberJackTN
Updated shared photo file. Glad to send anyone interested a link to that.
  • Very light oil drip is showing at the bottom of the bell housing where engine oil forms a drop. Not enough to even stain the driveway, but it is there.
  • Weeping, but not leaking around transfer case.
New price: $8K
You cannot buy from a better person that @weejub. Great guy you can trust whatever he says is the honest truth.
GLWS.
Waffle - I'll send you a message. Thanks!
