For Sale 1996 FZJ80 Landcruiser 105,### miles
Boston, MA
I'm selling my low mileage 1996 FZJ80 Landcruiser (no Lockers) with a decent list of upgrades & PM. Selling only because I'm now into a fully locked diesel with similarly low mileage.
Completed Work (Preventative Maintenance)
New Radiator: Completed @ 80,000
Soft Brake Lines: Complete @ 84,000
Rear Heater Coolant Lines: Complete @ 84,000
Tune-up (Belts, Fluids [Engine Oil, Front Diff, Rear Diff, T-Case]): Complete @ 86,000
Frame Maintenance (grinding, inhibiting, sealing painting): Complete @ 86,000
AC Compressor: Complete @ 86,000
Master Cylinder: Complete @ 86,000
Remanufactured Calipers (Toyota OEM): Complete @ 90,000
Jonesy's Knuckle Rebuild / Brake Upgrade STAGE II BUNDLE: Complete @ 90,000
- 4 x Koyo Trunion Bearings
- 2 x Toyota OE Inner Axle Seals*
- 2 x Wheel hub seals*
- 2 x Hub gaskets
- 2 x Dust seals
- 2 x Spindle lock washers
- 2 x Dust seal gaskets
- 2 x Spindle gaskets
- 2 x Felt gaskets
- 2 x Metal Backing Plate sets
- 2 x Metal Wiper Rings
- 2 x Rubber wiper seals
- 6 x Moly Grease Tubes
- 2 x Front Wheel Bearings 360 Performance Drilled and Slotted Rotors, Premium Ceramic Brakes
U-Joint, Front Driveshaft, Transfer Case Side (Toyota OEM): Complete @ 92,000
O2 Sensor gasket replacement: Complete @ 94,000
Distributor O-Ring Replacement: Complete @ 96,000
New rubber seals, grommets, etc.: Complete @ 96,000
DENSO Starter Replacement: Complete @96,000
Valve Cover Replacement: Complete @ 96,000
POR-15 Frame Treatment: Complete @ 102,000
Exhaust Manifold Gasket: Complete @ 103,000
O2 Sensor replaced: Complete @ 104,000
Engine oil replaced every 3K with synthetic
Completed Work (Performance & Capability)
255/80/17 KM2 Tired with 4th Gen 4Runner Rims: Complete @ 91,000
FJ80/LX450 Land Cruiser Snorkel: Complete @ 91,000
MetalTech 4x4 Tube Sliders: Complete @ 92,000
Pintle Hook Complete @ 93,000
Ironman 2" Lift Kit with Foam Cell Shocks / Damper Complete @ 93,000
Center Differential Lock Switch 95-97: Complete @ 93,000
7-Pin Modification: Complete @ 94,000
Kicker rear door speaker installation: Complete @ 94,000
Whole-Truck LED light overhaul: Complete @ 98,000
Kenwood Bluetooth Receiver (KDC-BT558U): Complete @ 98,000
Load Sensing Proportioning Valve (LSPV) Replacement: Complete @ 99,000
High-Intensity Headlights: Complete @ 100,300
Duralast Battery: Complete @103,000
Custom Steel Bumper with Winch Plate & Headlight Hoops: Complete @103,000
Custom Steel Roof Rack: Complete @103,000
The Good: Leather interior is in much better shape than most, showing minimum wear and tear. Comes with mint third-row seats. Plenty of tread on tires. POR-15 on the undercarriage.
The Bad: Dashboard LEDs flicker; probably best to go back to more reliable bulbs. Side view mirror adjuster button is broken, but I have a working replacement. e-Brake needs tightening. Oil pressure gauge reading "0" at all times (gauge fault). Driver side plastic fender flares have some deep scratches. Passenger side front flare has 1-2 clips missing by rock rail. Easy to fix, replace or remove... whatever. Also has the usual pin-striping you'd expect on a rig that's seen trails.
The Ugly: Trail ding on passenger side door (not pictured in most shots). Plasti-crud on hood covering minor clear coat fading. CB currently transmitting but not receiving. Rear bumper trim is begging to be removed.
Listing at $11,000. Roof rack NOT included in selling price. Located near Pittsburgh, PA.
[/URL][/IMG]
