Here's my write-up from a while back on replacing the speakers in my '93 - I was really interested in keeping it stock looking and went with Eclipse speakers to utilize the stock grills (shallowest mounting depth available). I've heard since then (from other members here) that the 5 1/4" 2-ways I went with have been replaced by 5 1/4" 3-ways (same depth)...and have also helped a buddy put the 6 1/2" 3-way (have to use Eclipse grill with these). Your biggest problem is the window brace behind the front speaker - it gives you a fixed depth and anything you buy has to go out from there. Lots of members have fabbed different trim rings to account for this - just remember to check door closure with the panel in place (dash clearance an issue) -
Good Luck!
Tucker
Good Luck!
Tucker
they are quite heavy for just a screw through nylon spacer that I was orginally going to do.
