Parting Out 1993 FZJ80
Shawnigan Lake, B.C.
This one came to me with no history, some parts were already missing so no chance of running it (including someone chopped the engine fuse box out with what appears to be gnawing on it with their teeth).
I have never run this engine or driven this one.
The engine looks like it has sat for a long time.
Coolant (Before I pulled out the radiator) and oil are full and clean.
The left outside door handle is there, pulled it for a time waster...
Approx. 200K, can confirm ODO if concerned.
Front Diff is SOLD
Shipping from Canada on your dime.
I am looking for a knock sensor and a wire pigtail for it also. Shipping to Las Vegas
Thanks
I'm sure its there to check...How much of the harness do you need?
Toyota
Front Diff is SOLD
Is the driver side front power lock actuator still working? If so, how much? Thx
Can remove and test if you wish, $75 USD shipped.
looking for the driverside floor wire harness shipped to buffalo ny
This one? $150.00 shipped, the size wrapped up in a box and distance will make it pricey for shipping.
ok, Please keep me posted if it works. Thx
I can confirm applying power and ground to the red and black wires cycles the actuator back and forth. That's the extent of the testing I can perform on the latch.
how much for the rear slider windows shipped to 59860?
Shipping glass is always a crap shoot but I've done it with thin plywood on either side (adding to weight and cost) to protect glass. $300.00 USD shipped for both sides. This might be one to source a bit closer to you.
yea ill keep looking, never hurts to ask. thanks though
