Build 1992 PZJ75 --- build / maint / whew.
That light is for the timing belt, it comes on every 100k km indicating that the belt, tensioner and idler should be replaced. If you don’t have a record of if/when it was last done I’d get on that right away. Good to replace the water pump at the same time too.
Awesome thanks its going in tomorrow will add timing belt and water pump to list
yeah seen it. following you and @John Young
Did I mention I bought another one? For no reason really, other than I am about to ship the diesel pickup back to Virginia--the papers have arrived in Dubai just yesterday.
truck is at the shop for service. lots to go through for mechanic. drove fine, shifting was hit and miss. going to have them replace clutch regardless for piece of mind. also told them they have to pull the one that's in there because that is not the transmission that came with truck.
new stereo and sound deadening on order. pretty much everything oddiron offroad offers for 70 series headed this way and this is first shot from partsouq to get into jordan. there will be more, just testing the customs procedures with the first one. also will probably replace the metal door inserts with covered wood similar to how I did an RJ77 last year.
8156060342LAMP ASSY, REAR COMBINATION, LH
9011908511BOLT
5543260090S7PANEL, INSTRUMENT PANEL FINISH, LOWER NO.1
9016840043SCREW
6481160010GLASS, BACK WINDOW
6481290K00WEATHERSTRIP, BACK WINDOW GLASS
1780161030ELEMENT SUB-ASSY, AIR CLEANER FILTER
9091602452BELT, V(FOR FAN & ALTERNATOR)
1987947665BELT
8431060571SWITCH ASSY, TURN SIGNAL
8313860040GLASS, SPEEDOMETER
5541390K00PANEL, INSTRUMENT CLUSTER FINISH, CENTER NO.2
6.92601E+11HANDLE ASSY, FRONT DOOR WINDOW REGULATOR
KS1007STEERING DAMPER
4321260090KNUCKLE, STEERING, LH
9036547013BEARING (FOR REAR AXLE SHAFT)
444106SHOCK ABSORBER TO LAND CRUISER FRONT RH/LH 1987- KYB
4853169396SHOCK ABSORBER
9010512104BOLT
9017912086NUT, STEERING WHEEL SET
1356819065BELT, TIMING
1610019235PUMP ASSY, ENGINE WATER
1350517011IDLER SUB-ASSY, TIMING BELT, NO.1
9050727001SPRING, TENSION(FOR IDLER)
8534989122JOINT
mechanic is finally getting to this.... customs has been a huge issue. if anyone is sending stuff to Jordan, stay away from FEDEX. items didnt clear from 08 OCT arrival until two days ago. I was able to get most everything else through APO, thankfully.
list of what's being worked this week:
BUSH, HEADLAMP CLEANER WASHER JAR
HOLDER, WASHER NOZZLE
CABLE ASSY, SPEEDOMETER DRIVE, NO.1
ROD SUB-ASSY, FRONT DOOR LOCK REMOTE CONTROL, LH
ROD SUB-ASSY, FRONT DOOR LOCK REMOTE CONTROL, RH
SCREW, HEX LOBU
LOCK ASSY, FRONT DOOR, RH
LOCK ASSY, FRONT DOOR, LH
HANDLE SUB-ASSY, FRONT DOOR INSIDE, RH
HANDLE SUB-ASSY, FRONT DOOR INSIDE, LH
GROMMET
LINK ASSY, FRONT DOOR OPEN CONTROL, LH
LINK ASSY, FRONT DOOR OPEN CONTROL, RH
HANDLE ASSY, FRONT DOOR, OUTSIDE RH
HANDLE ASSY, FRONT DOOR OUTSIDE, LH
SNAP, DOOR OUTSIDE HANDLE
BOARD SUB-ASSY, FRONT DOOR TRIM, LH
SHEET, HEATER CONTROL NAME
BOLT
SCREW
GLASS, BACK WINDOW
BELT
GLASS, SPEEDOMETER
BOLT
BELT, TIMING
JOINT
1 × Front Axle AISIN Hub/Drive Flange Stud Hardware Set
OEM Toyota Key - KEY00212
Dash Pannel - OEM Toyota - Fits 7x Series (INT90K00)
Pedal Pad - OEM Toyota - Fits 7x Series Brake & Clutch (INTPP14020OEM)
4 × Interior Door Handle Screw - OEM Toyota - Fits (2 Required per Door) (INT10010SC)
1 × 7x Series Knuckle Rebuild Kit - 01/1990 - 07/1999 70 Series Land Cruiser 6-Lug w/Manual Hubs
RAK9397FFELK - Cruiser Teq Full-Float Rear Axle Bearing/Seal Kit
TRE69105 - 555 Tie Rod End Kit
2 × U-Joint - Fits 1/90 - 1/98 7x/8x Front UJ35031 - U-Joint
BR60011 - Rear Brake Shoes - Fits 7/1980-12/94 4x/6x/7x/80 & 1/1990-7/99 7x Series w/Rear w/OE Drum Brake
BRAD0436 - Front Brake Pads - Fits 1990+ 7x Series & 1989-1995 Truck/4Runner (ADVICS)
HUBFLG60010 - AISIN Hub to Wheel-Hub Gasket
BRR601807X - Brake Rotor 2x
FA15007 - 54 MM Hub Socket
FA301038 - 50 MM Front DRUM Hub Socket
× AISIN Locking Hub - Fits 1/90-1/99 7x/8x Series w/6 Lug Wheels (Gold)
HUB6997KASET - Front Axle AISIN Hub/Drive Flange Stud Hardware Set
FAXT60040JP - Heavy-Duty Replacement Birfield/Axle Kit
BWCR60120 - Wheel Cylinder - Rear All
1 × Thermostat - Fits 1HZ/1HD Engines - HZJ7x/8x & HDJ8x - 76°C/170°F (RAD03089)
1 × Thermostat Gasket - Fits 8/1992-12/97 FZJ80 w/ 1FZ Engine & 1/1990-7/07 HZJ7x/8x & HDJ8x/10x w/ 1HZ/1HD Engine (RADOR66020)
OME GP1 Old Man Emu Greasable Spring Pin Kit (Pair)
1 OME GP2 Old Man Emu Greasable Spring Pin Kit (Pair) - 50mm
1 OME GS1 Old Man Emu Greasable Shackle Kit (Pair)
1 OME GS2 Old Man Emu Greasable Shackle Kit (Pair)
1 OME SD24 Old Man Emu Steering Damper - 6x/7x/8x
2 OME SB1 Old Man Emu Spring Bushing Kit
2 OME SB16 Old Man Emu Spring Bushing Kit
4 OME U51 OME U-Bolt
4 OME U59B OME U-Bolt
2 OME60009 OME Nitro Sport Shock
2 OME60010 OME Nitro Sport Shock
clutch
ac compressor
wheel studs
wheel spacers
lug nuts
all fluids, etc. installing AC, making sure heater works.
new wheels... 17 inch Hilux Steel wheels with Michelin LTX AT2 235/80r17. wheel spacers on hand if required.
needs some body work also, will get that taken care of here as well.
update. still in shop. electrical being gone through. and I mean all of it. new leaf springs installed as well. ordered most components from @cruiseroutfit. told local shop I couldn't get the springs due to weight and customs being 70% tariff if I FEDEX them. they had local spring shop fab up 5 cm+ springs. haven't seen it in person yet. soooo.
hopefully within next few days... now to decide if I want to keep it same color. paint job here under well under 1kUS complete, and thats almost double most rates here.
Just some chinese led's. Was in truck when i picked it up from Bedouin. Can get more detail for ya once I finally get it back in my possession.
got it.. finally. didn't get to drive much. tomorrow will air it out. AC and heat both working.
doing stereo tomorrow. head unit, amp, speakers, dynamat.
will go in Saturday for body work. paint. still undecided on color change. 6L4 is looking good, or leave whatever color this is. original was 045 white, so it will not be original no matter what.
back in the shop. new radio, speakers, amp, etc.
also Dynamat installed. told guy to toss the Bedouin floor cover. hand sewn plastic and all. have to try and source a new something another now.
seats will get a go over soon too. looks ok in pics, but they are tied together with rope in the back.. or bedouinized as I call it.
taking shape
lockdown day here (Friday).. so got the weather stripping and seals on the way for paint. and the hood latch is not so good. combination partsouq and megazip. will take a week or two to get it all together, hope to have truck back Sat or Sunday and start putting miles on it.
6817090K01WEATHERSTRIP ASSY, FRONT DOOR GLASS, INNER
6990290K00CHANNEL SUB-ASSY, FRONT DOOR GLASS, LH
6821110030CLIP(FOR FRONT DOOR GLASS INNER WEATHERSTRIP SET), RH/LH
6777112050CLIP (FOR ROOF SIDE GARNISH), RH/LH
6818190K00WEATHERSTRIP, FRONT DOOR VENT WINDOW, RH
6818290K00WEATHERSTRIP, DOOR VENT WINDOW, LH
6817690K00WEATHERSTRIP, DOOR VENT WINDOW GLASS, LH
6817590K00WEATHERSTRIP, FRONT DOOR VENT WINDOW GLASS, RH
6814190K04RUN, FRONT DOOR GLASS
6821090K01WEATHERSTRIP ASSY, FRONT DOOR GLASS, OUTER LH
6816090K01WEATHERSTRIP ASSY, FRONT DOOR GLASS, OUTER RH
6786260040WEATHERSTRIP, FRONT DOOR, LH
6786160040WEATHERSTRIP, FRONT DOOR, RH
6822090K01WEATHERSTRIP ASSY, FRONT DOOR GLASS, INNER
5351060230LOCK ASSY, HOOD
5363090K02CABLE ASSY, HOOD LOCK CONTROL
6316190K00WEATHERSTRIP, ROOF
6315190K00SEAL, ROOF PANEL REINFORCEMENT
9011906265BOLT
6589690K00CAP, COVER TOP SET BOLT, RH/LH
9011908479BOLT
6316390K00SEAL, ROOF PANEL REINFORCEMENT, SIDE
7811195110PAD, ACCELERATOR PEDAL
331190K0308HEADLINING, ROOF
64837-90k00Weatherstrip, Cab Back Panel, Center, Toyota
6905790K11Cylinder & Key Set, Ignition Switch Lock, Toyota
58510-60780-06Mat, Front Floor, Front, Toyota
6786260040Weatherstrip, Front Door, Lh, Toyota
turned in for paint / bodywork. expecting a month.
running fine. fuel gauge may be stuck at full. not sure if aux tank is feeding main, had them both filled at same time, was on about 1/8 tank, went to F. drove 200 or so miles, still on F.
Jordan Customs and DHL are screwing around with weather stripping shipment, has been in country since 21 DEC, still don't have. but soon. . Inshallah and all.
close to decision on color, probably mercedes Stone Grey, place does a Standox liner for industrial equipment, so getting that in bed. local Linex is out of well, linex, and is not sure when he will be resupplied.
dropped off first customs shipment of weather stripping, hood latch, etc. complete robbery in Jordan on customs. literally now at 100%. they just make s*** up as it comes in. DHL is about as bad here as customs.
doors off, bodywork almost complete. color chosen, paint starts soon. went way away from what the guys were expecting and caught the owner off guard. unique 75 coming up. will have liner in back, on rocker panels, and bumpers, hood will have black also, where it rises on left and right, blacked out on emblems, door handles, etc.
they are taking top off to get interior done.. originally going to be close to what was on it, so wasn't worried about interior so much. but with complete change, inside getting done, dropping windshield as well to get dash good. 4X0 can't wait to see it now.. have interior guy lined up also to get new floor vinyl that doesn't look like an old trash bag that was sewn together.
paint update and attention to detail from these guys is crazy. not complaining. they are going to take a look at fuel gauge issue I am having as well. no rush, but looking forward to seeing it completed. anything else maybe to address while its in this form?
