1992 3fe VAF “MAF”
So I parked my rig last night.woke up this morning to change the oil. Went to crank it up. Starts up and I mmediately dies. Runs for 1 second maybe 2. Dead gas pedal. Fuel pump replaced 2 months ago. Could this be a indication of a bad VAF? I will test when I can pick up an ohm meter. Am I on the right track. This as been a very reliable rig. Maybe I have noticed the fuel mileage getting worse over the last couple weeks. Any and all help would be great. I need it running for a up coming deer hunt my son has.
Unless you've been yanking on the VAF, I doubt it. I would be more inclined to think it is ful pressure regulator or fuel related.
@jonheld has a diagnostics list (do a search for it) for the 91-92 trucks that addresses these types of issues.
Your 3FE has an air flow meter (AFM).
The fuel pump is fired from the starter circuit through the first coil in the circuit opening relay (COR). When the flap in the AFM opens as the engine begins to suck air, it fires the second coil in the COR to continue to run the fuel pump.
Suspects are:
Flap in the AFM is stuck closed
Intake tube is removed or badly torn
AFM connector is removed or damaged
COR and associated logic
You can bypass all fuel pump logic by jumping pins 8 (B+) to 1 (FP) on the diagnostic connector on the firewall. Keep in mind that this should only be a temporary diagnostic test and not a "fix".
Suspects are:
Just out of curiosity Jonheld.... were you/are you a Toyota Master Tech? I’m just curious, because I’m 50 years old and I can honestly say that I’ve never ran into someone that knows SO much about Toyota’s!! Ive yet to see you be “wrong” on a diagnostics question...... amazing! Mad respect to you sir!!
I'm an engineer, so I'm wrong all the time by default;)
It's 1986 technology. There's no magic to it. Keep a hard copy of the FSM and EWD within easy reach in the bathroom.
My Toyota knowledge is very limited to the 3FE but I'm starting to figure out the 1FZ.
Thank you guys so much. I have bypassed the fuel logic. I have also replaced VAF with a known working unit. No change in symptoms. I have ran a code check and came up with code 24 intake air temp sensor and 32 air flow meter signal. Ok so this truck was running fine. I drove it the night before. I changed the oil the next morning. This is where things may have went sideways. When I replaced the filter I did not notice that the gasket from the old filter was left on. So when I twisted on the new one it did not seal tight. I did not notice until I tried to start the truck. When I got in to start the truck to make sure the oil pressure was good. Is when it first acted up. In wasn’t until me trying to start it a time or two until I realized I was spilling out oil from the new filter. Could I have messed something up then? I would not know what. But just full disclosure. Let me know what you guys think.
Did you remove the top of the air cleaner with the large intake tube when you changed the oil filter?
Have you checked that large intake tube for cracks or tears?
Were you getting those codes with your original AFM?
Are you certain that B+ and FP are connected at the diagnostic connector? The pinout is here:
I did remove air filter. I can not see any crakes in hose. I have replaced the big hose with a silicone version. When I jumped the pins I could hear the Pump run. I pulled no codes prior to putting the new AFM. Is there anything I could have disconnected around the oil filter with my dumb gorilla hands. With the cor. Am I right in thinking that it kicks on the full pump on start and then kicks on the AFM when fule picks up. Again, it fires right up then flutters down. The gas pedal is dead. I guess for 60 bucks it’s wroth getting one and throw it in.
Then replace your old AFM. It's probably good.
What do you mean by, "The gas pedal is dead"? Is your throttle cable broken?
By jumping the pins on the diagnostic connector, you have bypassed all fuel pump control. The FP will now run as long as the key is in the ON/RUN position. If it's firing briefly while cranking the starter and stalling after you release the key from the START position, then you are not getting fuel.
Please re-read post #4 which describes how this system works.
Listen to this man @TBDAZ do what he says and you will end up saving a bunch of cash. These rigs don't reward those who attempt repairs by blindly throwing money at problems, they will empty your bank account, kick you in the nuts and dump your ass in the projects faster than you can imagine.
Amen to that!! Jonheld giving advice is sort of like talking to the man on the silver mountain! You think he’s a myth until you actually get to correspond with him! Lol
