1991 3FE cutting out issues
I recently took my Cruiser to the mountains for a day out. It worked great on the way out but after several hours of driving it started to bog out when I would accelerate. The RPMs would drop to below 1000 and it would chug up to around 35 mph then repeat the bog out. What could be the cause of this problem. I got it home and let it sit for several hours and took it for a short spin and it was back to normal. Any help would be great.
I'm no mechanic, but my rig acted like that once and it was a dirty fuel filter.
Only thing that puzzles me about yours though is that it went back to normal...
Sounds exactly like my 91. It only does it on the drive home, after a few hours of wheeling.
I've replaced the fuel filter, and that didn't fix it. It's definitely something electronic.
Here's the weird part...
I can be driving along at 55, and it will start acting up (bogging, cutting out, very little power), and I can throw it in neutral, turn it off for a few seconds, then fire it back up and I'm good to go for about 5 more miles. Then it starts acting up again.
The first time it did it, it took me about 2hrs to drive 30 miles... then I figured out that turning it off and then back on fixed it for a while.
Anyone have any clues? Ignition coil maybe?
-Tim
Hmmm, now that I think about it, i guess it could be the fuel pump going out? But, would shutting the vehicle off for a couple seconds cause it to start working fine for a while?
-Tim
Try replacing the screen on the fuel pump. Sometimes it will get clogged up and collapse on itself. If you let it sit for a while then things settles and it will let up.
Driving through any water? My 3FE did that when I didn't have 02 sensors in, and the connectors got wet.
if it only did it once and hasnt done it again it could just be something as simple as bad gas
never mind I just saw that it has happened more than once.
I would find a buddy or fellow TLCA member in your area and start swapping on some of his things to see if it goes away. I had a problem with my camaro once and swapped parts from my friends vette untill his MAF solved the problem on mine and saved me mucho $$$$ on a mechanic finding the problem.
A failing fuel pump can cause the symptoms you describe.
If it's failing due to overheating, the few seconds of rest can allow it to cool enough to work for a little while longer.
They're fuel cooled normally. If you frequently run your tank to near "walk the :censored: home", it's not getting cooled anymore. Do this long enough, and it will go bad.
Buy/rent/borrow a fuel pressure gauge and test the pressure next time it happens.
Also, IIRC, the fuel pressure regulator can cause similar symptoms. Check that as well. I think it's vacuum controlled on the 3FE? A cracked or rotting vacuum hose might be causing it to dump pressure back to the tank.
check your intake hoses. it is very common to find that the intake hose right at the intake manifold is torn between one of the ridges.
A failing fuel pump can cause the symptoms you describe. "Snip" If you frequently run your tank to near "walk the :censored: home", it's not getting cooled anymore. Do this long enough, and it will go bad.
My time is thin on the fuel pump. Time to keep turning left.
We have a winner!
The FP intake filter is a soft mesh. It will collapse on itself after an hour or so of driving. When you shut the motor off it will expand back into shape, but once the fuel in the tank is warm it will collapse on itself in a short time.
These filters should be replaced every 100K miles (just like the fan clutch). No one knows they exist and they'll swap in a new fuel pump with a new pre-filter and it'll solve the problem.
Spend a few extra sheckles and replace all the gaskets and cushions as they're most likely old and crusty.
I have a similar symptom with my 62 right now...and ordered a pre-filter for the tank, and a coil, along with a few other part$.
I have two questions, though...first, does the problem clear up if you drive in 3rd instead of drive? Mine does...also if I am going over 55 mph, it is greatly reduced in drive.
And second, is your fender-mounted blower operating? Mine isn't...:mad:
What I'm getting at is that you may be overheating your intake and fuel rail, like I am. I'll know tomorrow if I'm right, as I am hot wiring (fused) the blower for the ride to work.
I'm still going to change the pre-filter, though. It just seems like it should be done regardless.
Good luck...
