Wanted 1988 FJ62 wiring harness
Denver, CO
I need the harness that comes from inside the car out of the rubber grommet circled in this picture. Anybody have it?
Isn't that the engine/efi harness? I have one from a 1988, but ... some moron cut off the connector for the distributor before I harvested it. The rest is there if you can use it. $55.
Another option. A buddy and I have been harvesting from a 1988 truck. The harness is still there (as of last Thursday). I can check in a week to see if the connector is there.
Do you have a picture of it? I am so confused about where things come and go to on this. Several connectors that run the EFI are on the other two harnesses that come from the firewall by the fenders. This one I think goes to the distributor and the starter, maybe? I need to see it to know for sure. Since mine is cut up I can't find the ends that went to the neutral safety switch, the starter, the distributor and the fuel pump.
The engine harness has connectors for:
• ECU (2)
• Main harness
• Fuel injectors (6)
• Cold start injector
• Ox sensors (2)
• Cold start time switch
• Water temperature switch
• Water temperature sensor
• Water temperature sender
• Throttle position sensor
• Idle speed control valve
• Distributor
The main dash harness has EFI connectors for:
• ECU (1)
• Engine harness
• Air flow meter
• Ignitor
• Main relay
• Circuit open relay
• Vacuum switching valves (3: AI, EGR, fuel regulator)
Here is a pic of the engine harness I have:
