- Joined
- Dec 27, 2012
- Threads
- 1
- Messages
- 1
The hood latch on my FJ60 won't release by pulling the cable. Does any one know how I can either bypass this or adjust the cable from in the cab?
I have the same issue. What has worked for me to get it open is pulling up on the hood while someone pulls the handle; almost as if i was prying the hood open. Sometimes i push the hood down to completely relatch between pulls.
For me, the handle pulls out and even makes a small click at the hood, but it doesn't release. I've tried pushing down on the hood while someone pulls the handle, but never releases. Repeated handle pulls and pulling the hood up has eventually worked, but still looking for a permanent fix. (FYI I've greased the mechanism while open, and handle pops the latch perfect when I close the latch with a screw driver while the hood is up)
hood cable is cheap and takes less than 15 min to install. do it before you have a need to get in the hood quickly and regret it.
How does that work? the grill is bolted to the hood latch. I just replaced my hood cable and am reluctant to close the hood without being able to open it again if my replacement went wrong. I had to unbolt the latch to hook the cable up and as an added bonus i snapped one of the side bolts on the latch when i was tightening it back.If your cable is broken, you can remove the front grill and access the latch. Just a few screws. Be careful you don't break the brittle plastic latches of the grill.
Yeah I don't think it's that easy. There are some other threads on this issue where the hood won't open. Not easy to get to unless you want to ruin the grille and take it out in pieces. Some have had luck coming up from below with something to push on the latch, but it's difficult as I understand.How does that work? the grill is bolted to the hood latch. I just replaced my hood cable and am reluctant to close the hood without being able to open it again if my replacement went wrong. I had to unbolt the latch to hook the cable up and as an added bonus i snapped one of the side bolts on the latch when i was tightening it back.
it is an other odd situation for sure. my new cable is working so I need to drill out the broken screw and get a new one in asap and all should be well. thanks for the advice!Yeah I don't think it's that easy. There are some other threads on this issue where the hood won't open. Not easy to get to unless you want to ruin the grille and take it out in pieces. Some have had luck coming up from below with something to push on the latch, but it's difficult as I understand.
When I was setting up my latch and hood adjustments, I did it with the grille removed. Then when it's all working perfectly, then put the grille back.
