1984 FJ60 Heater Hose Inquiry
Climate Best by Government Test
My sons 60 popped a hole in this hose. Is this still available from Toyota? Can anyone guide me to the correct part number or a comparable hose from Gates? Thanks in advance!
See post # 3, 4 & 47
Looks like it's a 87245-90A01, now no longer available but a Gates 28467 works but need to be trimmed about an inch on the short end.
I used it on my 87 60 a couple of years ago. It has held up fine.
Don't use a razor blade to cut that old hose off. The brass fittings it attaches to easily gouge and if gouged may result in leaks.
A pick inserted horizontally and moved around the pipe should free up the hose to pull & twist off.
and using worm drive clamps can crush and distort the fitting
the stock wire clamp is desired
