Build 1982 FJ60 - Project Clifford
Knocked out a couple of quality-of-ownership type upgrades. Rear hatch struts were shot, so I snagged a couple of replacements and popped them in. This should have been super straightforward, but the captive nut on passenger body end broke loose and dropped down into the body cavity, never to be seen again. Fortunately I had a matching nut for the new stud. I recruited my 7yo, his small hands, and a piece of double-sticky tape to get the nut up into the body where I needed it. It's officially his first contribution to the truck project, which I'm excited about. I'm confident that some day he'll realize this thing is awesome; for now his assessment is just "it's hard to get into." 😆
I also swapped out the original mirrors for a set of 70 series mirrors from City Racer. They are just as advertised - an easy swap with a bit of a gap between base gasket and body that I'd call inconsequential. It's well worth it in my mind for the much-improved field of view. 👍
Filled the fuel tank today for the first time since owning it, and when I got home noticed a leak from the top of the tank. As best I can tell it's coming from a bad connection to the braided line in the picture. Based on a couple of FSM schematics I think this is the vent/overflow line that runs up and connect to the filler neck.
Can anyone a) confirm this and b) tell me the diameter of this line? I'm slowly replacing fuel line all over the truck, but this one appears larger than anything I've swapped out so far. Thanks in advance!
No, but if you want to go ahead and replace them all @cruisermatt has a great kit
Great tip, thanks!
So I had to apply some systems thinking to Clifford's backend this week. I want to tackle the leaking fuel tank vent line and replace the other soft lines while I'm at it, but with a fresh fill-up I have some driving to do before it's low enough to lower the tank without the headache of draining or supporting the weight. That's okay because I need to drop the spare tire support crossmember anyway to replace the lift carrier/winch doodad so I can carry a spare there (it came with no spare and a partial winch/lift). And I also want to clean up some rust back there. And I'm putting a trailer hitch on. Whew.
So...I started by pulled the rear bumper. It was a humbling experience and involved my first bit of swearing at the truck while dislodging what seems to be original hardware that hasn't been touched in 44 years. I pretty quickly rounded off most of the square-shoulder button-head bolts, and things escalated. There was a great deal of grinding involved from that point, and the hardware...didn't survive. 😆
But the bumper is off! In the grand scheme of things and in comparison to lots of pictures I've seen...I don't think this rust is very bad at all.
I'm now getting to work cleaning up the bumper and frame, it's coming along nicely. More to follow!
The chronology is off, but late last week I got Clifford up in the air for the first time to take a really good look around and to tackle the exhaust situation. A PO cut out the original assembly and installed an aftermarket muffler around where the cat originally was. The rest of the system was gone, and the pipe ended under the driver just past the muffler. Driving it resulted in some low-grade CO poisoning, which was pretty unpleasant.
I cut out the old muffler and cobbled together a Walker tailpipe (Walker 46678, $48 from AutoZone) and a universal muffler, plus a section of 2" pipe to get from the cutoff to the front of muffler. I used the three frame exhaust support brackets but had to get a little creative for 2/3 of the hangers. The Walker tailpipe mounted nicely with an OEM rubber insulator to the rearmost bracket.
It was a fun project, and I got to learn how to use a hydraulic pipe bender/flare machine (the big blue guy in the background of the picture with Clifford on the lift). That's not something I expect to ever have in a DIY shop, and it does quick work once you figure out the multi-axis geometry.
The exhaust actually exiting behind the vehicle makes a huge difference, and between this and the no-longer-leaking carb I'm considering this thing suitable for daily driving!
I celebrated by taking it to a local meetup over the weekend. I didn't take any pictures, but I ended up parked between two other FJ60s - one with EFI via a swapped 80/3F-E head, and the other with a fresh LS swap. Talk about some future project inspiration. I did win cool points with my functional carb cooling fan. 😆
One more task last week - reinstalled and wired up the old KD bumper lights. Relatively quick and easy job with a generic wiring harness kit. It came with a basic rocker switch that fits perfectly in the (I learned after some research) hand throttle hole below the steering column. It's functional but cheesy looking. Maybe someday I'll do something fun like wire it into a factory switch, but for now it works and they look great.
Kudos to my wife (and @RevISK ) for recommending I keep them!
One thing about these old GM incandescent light units - they are basically space heaters that also emit light. I was standing in front of one as I tested the connections, and when it came on I almost sustained a burn injury to my crotch. You could cook a hotdog in front of these things...
I also continue to find hornet nests in the nooks and crannies. Darn things apparently loved this truck...
H4 headlight upgrade is ultra cheap at the local dealer. You can't go wrong for $20. Toyota Headlamp Assembly #81110-60P70 | Autoparts.toyota.com - https://autoparts.stevinsontoyotawest.com/products/product/headlamp-assy-8111060p70
Once you do the upgrade, you can get all fancy and swap out the H4 bulb for LED or whatever is in fashion this week. The Holley RetroBright lights are nice too, but about 10 times more than the Toyota H4 upgrade I linked above.
PO already did the H4 upgrade! This was on my list and I only realized it was done when I almost accidentally cut out the wiring while purging all the other remnant wiring. "Wait, this wire leads to that newer looking relay which leads to..."
A pleasant surprise, for sure. I'll definitely check out bulb options, but your comment made me realize...I haven't driven this thing in the dark yet! Adding that to the to-do list... :)
Does the blue high beam indicator work? If not, @CruiserTrash has a fix for that too.
Thanks for the shout!
I haven't posted about this anywhere yet, but those are currently marked as "sold out" on the website. I found out a few days ago that the most key component that goes into making those got discontinued. I need to not only find a suitable replacement, but that will also necessitate redesigning the PC board. All of that is going to take some time unfortunately.
Definitely maybe! I'll find out once I do my nighttime test drive, I suppose... 🤞
@CruiserTrash has been generous with his time and pointed out a few fun '82 quirks like glass fuses, no Choke or 4WD indicator lights, etc. If the high beam indicator is dead I'll just mentally add it to that list. 😆
I got busy on some rust today - rear frame, spare tire carrier crossmember, rear bumper. Wire wheel and brush, rust converter, and crossed fingers that I can not worry about these bits for...a year? A decade? The balance of my lifetime? Time will tell...
PS - I promise that overspray on the body was already there. 🤷‍♂️
Waiting on another round of parts but continuing progress on a few more little projects. I hit the local pick-and-pull last week to search for a VSV for the A/C idle-up (no luck) and 4Runner wiper arms (success!) per the recommended swap. I got them cleaned up and painted, then installed over the weekend.
I've owned a couple of 4Runners so it's fun to have this little mod on Clifford. And I always enjoy a lap through a pick-and-pull. It's impressive to see what folks are pulling out of those yards (this 4Runner's engine, e.g.), and fun to think about how many vehicles are kept going by these donor vehicles.
I got started reinstalling my windshield washer system today and the connection isn't pushing 12V power. I'm *pretty* sure it was previously, but also I am not 100% sure that I tested it when I pulled the old pump. I am sure I bench tested the pump and it was shot, hence the replacement.
Anyway...that's all okay because I generally don't mind chasing an electrical gremlin and am pretty comfortable with the process. I pulled the glovebox and started rooting around with the wiring diagram on the passenger seat and ended up way distracted. First, I came across this little guy and had to research what the "inspection socket" is. What a clever little feature those Toyota engineers gave us! 😆
Next, I found the original radio wires and one of its two connectors (the second was cut, sadly). This is an exciting discovery because there's an OEM radio in my PO-provided parts box. Clifford came with an aftermarket head unit and speakers that are all wired outside of the original harness. The original speaker wires were cut, unfortunately, but I'll be able to wire the aftermarket speakers into the OEM radio if it still works. I need to source a glass 5A fuse to get the radio circuit going again, so this project is unfortunately on pause. I have a bluetooth cigarette adapter thing to play music from the phone so I'm not going fully back to reliance on local AM/FM, but I think it would be cool as hell to have the OEM radio pulling in the adapter signal. More to follow! 🤞:)
I'll get back to figuring out the washer pump wiring...eventually. 🤷‍♂️
It also turns out that aftermarket dash-top speaker grille is just decorative evidence of past modifications. No speaker underneath, but there is some pretty significant damage to the dash pad. :(
I’m probably not the only one wondering so I’ll ask, what is the inspection socket for?
Toyota part number 81370-60010
That's where you plug in the inspection light. Photo borrowed from City Racer. Fun fact, the FJ40 also has this inspection socket.
Radio progress! Of a sort...
I removed the aftermarket radio and spliced connectors into the harness to replace the one missing connection to the OEM radio. I also spliced connectors into the aftermarket speakers to retain the original harness-side connectors (looking at you, @Spike Strip - good tip), and re-worked the stock-but-modified radio brackets to get the old unit back in there. PO bent and cut the brackets to mount the aftermarket DIN bracket thing, but they were salvageable. I also removed a bit more remnant wiring (aftermarket radio power - note the inline fuse rig :)) from the steering column while I was at it.
Hooked everything up to the OEM radio and...no FM. AM comes in great and all of the radio's other functions work, so I uninstalled the radio and very gingerly removed the case top to see if there was anything obviously wrong. I'm comfortable with electric stuff, but that's a wild can of worms in there so I promptly switched to finding a subject matter expert and came across work by @Engineer8000 . I'm now messaging with him to figure out a repair or replacement. 🤞
Until then...Clifford shall have a couple of dash holes. 🤷‍♂️
