For Sale 1981 BJ 42 (previously listed on forum) in Kelowna
Kelowna, BC
Hello I made the mistake of buying without talking to the wife so here we go.
This is basically a repeat of the last ad that was posted by the other seller.
I will accept cash or EMT or trade for older Jeep with some cash to me.
OPEN TO A REASONABLE OFFER ASKING $17,250
The work below has been completed in the last 3 years and it has not been used much at all
3B Diesel runs clear no smoke . This is the most sought after diesel as it has the extra oil jets on the piston skirts that allow turbo charging. Rear mainseal, oil pan and pushrod cover resealed
New Glow plugs
4 speed manual transmission, no slippage in clutch very positive shifts not sloppy at all. Trans and transfer case resealed,
Clutch bearing and clutch slave
Speedo cable including speedo changed to reflect 35 inch tires.
Valve adjustment done
Racor fuel / water separator installed
Front bucket seats with a newer rear seat that can easily be removed.
Rebuilt front locking hubs
Dick Cepek 35 “Tires and rims with stock springs
No leaks in exhaust and muffler is new original Toyota LC
Manual steering
Frame has been replaced which was sand blasted metal prepped and coated woth POR15
Front axle replaced with a cut and turned unit from EBI including larger spring perches. Axle was rebuilt entirely with new bearings, marlin crawler inner seals etc.
Rear axle sandblasted and rebuilt.
Third member replaced with a unit from a BJ42 with 50, 000 km
OEM axle breathers and extended lines
Heater, windshield wipers signals, horn all works.
Disk brakes all the way around. Working e brake with new master cylinder, brake lines and booster from a 60 series.
Heavy duty 4plus anti inversion shackles
BDS shocks and custom stock hangers
Manual gear box from low mile unit
Tie rod ends
Old man Emu damper to fit OEM position
Headlights upgraded
Heater rebuilt with all new hoses and fittings. Blows hot.
New fuel tank
Has a winch (Kodiak Bruin)but it needs a bit of TLC not mounted but have all parts including fairlead.
Have rear flare kit just have not installed.
Has removable mud flaps
Needs finishing with interior trim and window trim. Longer term would probably include a new or rebuilt tub. Has no drivers door lock.
This truck is an excellent candidate for a complete restoration.
Truck has been sprayed a few times and engine bay shows green on fire wall I believe the truck was originally brown.
Ph number 2508265218
