Combat Chuck said:wow, that sucks.
agreed!
wow, that sucks.
Looks like the Tundra was a wiser purchase than it seemed at first!
's 09 Runner. It tows it fine as long as you stay around town. I wouldn't tow it on an 8% grade tho (like going to GSMTR.) That's where the Tundra comes in.
Wow you guys have a late 80s truck on the lot? Or is this not at the dealership.
Don't have any pics but I pulled the truck in the shop late yesterday and it looks like the idle/throttle solenoid was the culprit. Aparrently they like to lose ground and it will make the truck idle super high. We stuck a test light in the terminal and it lowered the idle way down. One of the guys that has been working on Toyotas since before most of us were born came over and was looking at it. He went all Rain Man on the carb and told me he could fix it up if I ordered a carb kit, so I did. He replaced a few misc pieces and cleaned it up really well... apparently I had not done as good of a job as I thought. So, solenoid grounded out, carb cleaned up, couple new pieces and a couple gaskets later, should run like a dream. I'll keep the updates coming.![]()
Check the fuel cut solenoid while you're at it.
It causes the reverse of the idle solenoid problem, in that it won't idle at all.
They suffer the same weaknesses with grounding, and other wear-related issues.
Yeah apparently the solenoid I have is no good. We're trying another one now.
It would be worth looking into to see if they're rebuildable, I hate throwing parts away.
. Oh yeah!I got my hands on one. I had another carb with a good one on it. Truck is running really well now. I do need to get in there and adjust the valves. I think they are adjusted way too tight. The carb is good to go at this point. Checked the vacuum advance on the dizzy and it actually works! Very surprising. We had to do an emergency repair on the oil pressure guage line. It has an aftermarket guage with a plastic line and the line had a split. The copper is the way to go apparently but I think they must line it with gold based on the price...
So, currently on the list of things to do (random order):
Fix positive battery terminal
[STRIKE]
Install body lift on cab
[/STRIKE]Replace clutch
Adjust valves
Clean out cab and prep for bedliner
Primer and bedliner inside cab
Re-wire inline fuel pump
Fix wiring for alternator (will go into more detail later)
Figure out wiring for light circuit (make sure it's not still back-feeding into the ignition)
Go get wheels (yeah I know I said I was going to do this like 2 months ago)
Mount wheels and *slightly* used tires
I'm sure I'll think of and/or find more things.
With the exception of the bedliner in the cab all the rest of the stuff will get the beast. Oh yeah!
[STRIKE]Install body lift on cab[/STRIKE]
[STRIKE] Replace clutch[/STRIKE]
Adjust valves
[STRIKE]Re-wire inline fuel pump[/STRIKE]
[STRIKE]Fix wiring for alternator (will go into more detail later)[/STRIKE]
I like it and yes you can see everything, but as you said its gonna get beat up anyway so going this route touch up is easier!
Lowe Toyota said:I think the pillars are going to go back tan and the roof white
