NorCalBorn
- Joined
- Aug 31, 2008
- Threads
- 101
- Messages
- 1,855
*Realizes he knows this stuff but it's always worth having in a thread like this for others searching similar build stuff.*
Sam, things are coming together nicely. I wish I had your drive. I have been piddling on a v6 rebuild for several months and I need to call a guy about a 22RE block to freshen up for my pickup, not to mention all the other misc. things sitting in que, and you have gutted one and are now starting on a second.
Truck is going to be sweet when you get it all back together. Keep the updates coming, as was mentioned earlier, you keep the rest of us motivated to get off our butts and do something, well me anyway.
Well that is most likely my problem, my "boss" doesn't care to much about how long I leave my mess. That plus my 2 year old helper seem to make things take a little longer.
[STRIKE]Strip the mini[/STRIKE]
Clean and paint engine bay
[STRIKE] Install dash harness (also runs to engine bay)[/STRIKE]
[STRIKE]Install A/C box (if it will fit)[/STRIKE]
[STRIKE]Install A/C lines and condenser[/STRIKE]
[STRIKE]Install P/S (lines, reservoir, cooler)[/STRIKE]
[STRIKE]Install front end harness[/STRIKE]
Install air box (LF), [STRIKE]igniter (L), injector resistor (R)[/STRIKE]
Install throttle cable (incuding pedal and bracket)
Install fuel lines
Double check everything!!
Install engine and connect everything
Crank it up!![]()
Also I went ahead and ordered some Bomb Proof mounts from Trail Gear.
Hope you have good dental insurance. Your engine vibrations are gonna rattle your teeth out now.
Lowe Toyota said:Hey sweet my exhaust manifold is cracked! Luckily it is cracked in between the two chambers and not to the outside world. We're just going to weld it up as a temp fix and then someday (if I feel like shelling out $400) I'll order a header from LC for it... or just beat on it and forget all about the crack.
Also I went ahead and ordered some Bomb Proof mounts from Trail Gear. I was just going to slap it back together with the mounts from the Runner but it just makes more sense to go ahead and do it now. Then I won't ever have to change them again!
Don't waste your $$ on the LC header. I had a buddy that has had 3 on the same tacoma, from his experience they are junk and their customer service sucks. His header(s) all cracked at about the same place and they never offered to replace it for him only gave him free shipping or some BS like that on a new one. He ended up ordering a later model 4cyl manifold from the dealer and said that is what he should have done after the first one cracked. All that aside, these motors really don't benefit from a header. The stock manifold into a 2" cat (if your running one) and then 2.5" muffler to tailpipe will serve you well. A decent used manifold can be had pretty cheap, matter of fact I probably have one in my stash.
On the motor mounts, KLF is right. Those poly bushings are going to transfer alot more vibration into the frame, but since it isn't a DD you will probably be ok. I love the original 4x4 innovations t-case mount, which TG has copied, but I would want to know what the equivalent rubber bushing size is so that I could swap the polys out for rubber to cut down on the drive-line vibs.
I am interested to hear your feedback on the poly motor mounts and see if you get alot of vibration transferred.
