I have a 1980 20r pickup from Arizona. The harness is is bad shape - heat and POs did a number on it, though it the motor runs and most everything works. No smog equipment.
I just picked up an ‘83 with a beautiful harness.
T
My gauge cluster has a tach and gauges. The ‘83 just has idiot lights. The coil/alternator/voltage regulator appear to be different on the ‘83. ‘83 has an extra wire to the carb.
Otherwise, from what I can see, the harnesses appear to be the same.
Anyone swappped harnesses between the two? To be clear, I would swap the 1983 harness into the 1980 truck.
T
