SOLD 1979 2F air / smog pump brackets
Status
Not open for further replies.
Twin Cities, MN
Hi all--Looking for a set of air pump / smog pump brackets, etc. (and hardware too if you happen to have it) so I can mount my idler pulley. Thanks.
do u all the tensioner hardware and slider bolt parts too ?
- i have the UPPER adjust bar , pre-owned excellent condition
- and ALL the above needed OEM Hardware NEW
- i do NOT have the lower cast iron pivot bracket
i bet @EWheeler has this part for u ?
i bet he does
i bet he does
Thanks Matt, I dont have a spare bracket unfortunately.
do you have PS?
the 79 and 80 setup is different than the 81+
not sure if the bracket is the same,
the idler pulley assembly is shorter than the later setup to fit under the PS pump, but if you don't have PS it may not matter.
i bet he does
PMd you, thanks!
do you have PS?
I do not have PS, no, however I ordered the JimC idler that should be the "short" version to match my '79.
All sorted out, thanks for the responses all!
Status
