For Sale 1978 FJ40
High Point, NC
*Sale Pending*
It is with mixed emotions that I'm posting my Cruiser for sale. I want to move on to a new project, but can't without first opening up garage space.
Asking 14k obo
Located in Rochester, NY
Titled as a 1978 FJ40
Body
- 1977 tub with both driver and passenger floor pans replaced
- Rust free tub, fenders, hood and bib
Drivetrain
- Replacement “2F” sourced form CruiserParts.net (’77 block with a ’74 head)
- All new engine gaskets, water pump, oil pump, headers
- GotPropane fuel system
- SM465 4sp transmission w/ granny first gear (full professional rebuild spring ’15)
- Dana 300 transfer case (Novak adapter and 10sp input shaft, JB Conversions 4:1 low gears, JB Custom Fab twin sticks, Advance Adapters HD 32sp rear output, Parts Mike transfer case e-brake kit, 1310 front yoke, 1350 rear flange)
- 10sp GM clutch
- Resurfaced factory flywheel
- New Aisin pressure plate
- New Toyota TO bearing
- New fan clutch
Axles
Front
- Cut and turned FJ60 housing
- RCV 30sp chromo shafts with hub gears
- ARP hub and knuckle studs
- 4x4 Labs high steer arms, tie rod and drag link with 1-ton TRE’s
- 4.10 gears with Aussie Locker
- Aisin lock-outs
- Disc brakes with G&J Aircraft nylon coated stainless steel soft lines
- Tom Woods long-slip shaft
Rear
- GM 14bolt
- Solid 6 lug hubs (narrows WMS to ~62”)
- 4.10 gears with Yukon full spool
- Partial shave with Barnes 4WD 13-bolt diff cover
- GM ½ ton brakes
- Carolina Driveline 1350 CV shaft
Suspension
- Hybrid FJ55 front leaf packs in the front with 14” Bilstein shocks
- Rear double triangulated 4-link using Jeep TJ front coils with 12” Bilstein shocks
- TMR Customs 14bolt truss with pinion guard
- 2” sq., 0.25” wall lower links with Ruff Stuff heims
- 1.5” sq., .120” wall upper links with Ruff Stuff heims
- 108” wheelbase (front axle pushed forward ~5.5”, rear axle pushed back ~12.5”)
Electrical
- E-Z Wire 10 circuit wiring harness
- Roundeyes headlights
- LED tails (running lights, brake lights, and turn signals)
- Front amber turn signals
- Autometer gauges (water temp, oil pressure and voltage)
- Tiny Tach tachometer
- Trollhole distributor
- FJ60 alternator
- Diehard Platinum (Odyssey) 34/78 battery
Other
- (5) 15”x8” steel wagon wheels with weld-it-yourself beadlocks
- (5) 37x12.50x15 Maxxis Creepy Crawlers at ~90+% tread
- Full Metal Tech roll cage with seat cradle and tied into frame
- A to Z Fab DIY rear bumper with swing out
- Rock sliders with scab plates for frame
- Ruff Stuff Specialties rear frame box-in kit
- IPOR belly skid
- Metal Tech tube doors
- Hellfire Fabworks side mirrors
- Corbeau Baja Ultra suspension seats with PRP 4.2 harnesses
- ’93 Toyota T100 brake booster and 1-ton master cylinder
- Aisin clutch master and slave cylinders
- Zinc coated hard lines for brakes and clutch
- Saginaw power steering
- (2) 8 gallon forklift propane tanks (bought new)
- Bestop Soft-top (no doors)
- Trollhole trail top
The Cruiser is plated, but has not been inspected. It is probably 80% street legal for NY. The propane is tuned well – very little exhaust odor and doesn’t attract flies. As long as I can keep myself from breaking the transmission and engine, it wheels/crawls well.
Some general pics...
2015
2014
I have a bunch more pictures so just let me know what you would want to see.
Chris
I've seen this truck on the trail... it is very nice. Chris does meticulous work...
This truck is put together very well. Craftsmanship is excellent and Chris' choice of components very good. Whoever buys this rust free awesome rig is getting a heckuva deal! If I didn't have such a good 40 already I'd be all over this one.
Welp... my loss is your gain. Since the replacement engine is still not running the price has been dropped to $11k. At that price you're basically getting even more stuff for free. Quality parts, rust free body and good people helped me with it along the way.
Link to photobucket album Cruiser - For Sale Note: Powertank mount and fire extinguisher mount (on cage dash bar) are not included.
I would be willing to help with delivery (me towing) depending on location/distance. Should I get the engine running before it sells, price goes back up.
