1978 FJ40 - Wiring Help
Clemmons, NC
I have been fighting the wiring gremlins of the PO. I have several things sorted out but I am now tackling my reverse lights as they are not working. Your help may explain why the windshield washer is not working or why when I hit the brakes the turn signal indicators light up on the gauge cluster.
I have learned with this rig that if there is electrical tape anywhere just remove it and see what you find.
As a result I have the following questions based on the pictures below:
Picture #1 - any ideas what should be connected here?
Picture #2 - is this part of the reverse lights? (found this one behind the dash)
Picture #3 - can anyone identify the four wires in the picture
Diagram - is this one f the better references? (yes, I blew it up poster sized)
Any help would be awesome
Found an additional picture that show what the thicker black cable looks like. I have been searching around the forum and it looks like this wire may connect to the gearshift? That harness used to be green before it got covered with gunk from a leaking rear main seal
Great wiring diagram!!
If it's a '78 diagram, use it ;)
I'm on vacation and on an iPhone and colorblind... I can't make out a lot of what your pictures show.
1. Lite blue/red strip is "LR"... LR is backup lights... LR connects to the backup light switch on the tranny.
2. Can't see the colors... can't help
3. Can't read your questions... or see your wire colors... colorblind... I know they are there, but can't make them out.
So...
click this -->
Page 062 Land Cruiser 4 speed Transmission
Click the "backup switch location"
Click the image for your year
See the wired backup switch
Good luck!!
Maybe Rudi (@bj40green) or Mark (@Coolerman ) can see your pics more clearly.
I have a 78 transmission and it has the reverse switch and another switch on top of shifter tower. Read where it's supposed to work when transmission is in 4th. It's a single wire switch.
So...
click this -->
Good luck!!
Thank you for the help.
Thanks for the link. I will help you out with the colors as well
pic 1. is LR and connected the the reverse switch. I am not sure which of the wires from pic #3 goes to the switch as well
pic 2. WB and LR
pic 3. #1 LR #2 Light blue #3 Thick Black #4 light blue
DO you know what the one is for on the shift tower?
Here is what I used to redo my 78.
FJ40 Wire Harness Reference - December 1978
Believe wire in pic 1 is unused on a 78
Pic 3 wires. Ones on the left go to reverse switch on top of tranny.
Thank you. I am going to print out a large color copy of that harness.
Pic 1 - Glad to hear that the PO did not leave anything out on that one
Pic 3 - At there is a LR wire already connected. I am not sure what other wire to connect.
Posting for others. I did an H55F swap in my 40 a couple years ago but never got around to the reverse lights. I got the female cannon plug for tranny and associated OEM bullet connectors from Toyota Matt (thanks Matt). 12V for left and right side of reverse lights off the harness are both located on passenger side chassis roughly a foot behind the fuel tank. On a 78 FJ 40, LR is +12V and light blue is ground. Join the left and right + and - for each side together. Attach female bullet connectors, it doesn’t matter which one goes to which on the switch. Hope this helps folks get their reverse lights going on the 40 with an H55F.
