A couple weeks ago the hard line on the rear axle, between the T-fitting and the drum, sprung a leak while I was driving to work. I limped the truck home and ordered a set of hard lines from Cruiser Corps. That set ended up being a mess of duplicate parts and missing pieces, but it did have good fittings. I ended up cutting it all apart to salvage the fittings and making my own lines. I had intended to replace all the lines on the truck, but since making my own lines is a lot more work than using pre-bent lines, I only ended up doing the rear lines and will do the fronts over the winter. I bled the brakes and thought I had done a good job of it, but found the pedal to be very soft. I did some reading and checked the adjustment of the rear drums: very very loose. I adjusted the drums, but I think I could probably go tighter than I ended up with. I probably need to go through the rear drums pretty good over the winter. I bled the brakes again after adjusting the drums: feels better. Took it for a test drive: wait, better, but not a lot better. So I think the next step is to replace the vacuum line to the booster and maybe the check valve. It could be that the booster needs to be replaced too.
Is there anything that I'm overlooking?
