For Sale 1977 FJ40 Northern, Va 6k OBO
Upperville, VA
IMG_0090.webp IMG_0083.webp IMG_0090.webp IMG_0083.webp IMG_0084.webp 1977 Fj40 Dune beige
Mileage, 600754 - I'm guessing 1600754?
Bought it 5 years ago from a guy that brought it back form California. I desmogged it when I first bought it. Still have all the emissions equipment that was pulled off including the carb. Currently runs a bit rough but will Idle all day. When I put the Trollhole Carb and Dizzy on I only set initial timing, I'm sure in the right hands it should be an easy fix considering it ran fine on the Weber carb I had on it previously. I removed the Weber due to a shot diaphragm. Idles nice and cool with good oil pressure. Comes with many spare parts. Also comes with an old Warn 8274.
The good
New parts-
Trollhole Carb
Trollhole Dizzy
Coil
Radiator
Water pump/gasket
Radiator Hoses
Ignition switch
Thermostat/gasket
Temp Sending Unit.
Alternator is a few years old
Currently putting in new seat belts.
Lots of new bolts.
All new fluids.
Frame is in good shape with only minor surface rust in some places. (See pictures)
Top is in great shape.
Brakes work well
Lights all work
Heater works
The bad.
Engine runs little rough.
U-joints need attention- Get a vibration from the rear.
Shocks could use an update. Especially the passenger side rear upper shock bushing is lose.
Body is a bit rough. You can tell there was some patch work done I tried to show this the best I could in the pictures.
If you have any question or would like additional pictures please feel free to PM me.
Price is 6k OBO
adamsclarke- I'd say about a pound per square inch. Seriously though the spots that you can see an abnormal shape really show where the bondo is but I have no idea since I didn't do the work. Yes, you are correct on the bed liner on the lower half but again this is work I didn't do. For 6k its a driver if you take care of the few mechanical issues. I'm located dead in the middle of Middleburg and Winchester on rte 50. If you have any further questions feel free to PM me with your number and I'll give you a call.
That is a GREAT starting point for someone. I've seen some of the garbage that is for sale in socal currently, most of them don't even run much less have the complete rig as you do.
As above good luck with the sale, it won't sit long
