1977 & 1978 Distributors
North of Tulsa
I have an April 1977 40 that has the larger distributor. (see pic) I have not looked in quite some time but I thought this distributor was electronic (no points). I've read until 09/77 the distributor should be a points type. Can someone confirm if the distributor in the pic is correct for 05/77 and if it has points or not?
Also, a friend at work has a 1978 40 that he says has points. Should this have an electronic distributor?
thanks
Landcruisers built in Japan in 1977 reach our dealerships in 1978, and are sold and registered as 1978's- - -but the parts counter man would use a 1977 parts manual at the dealership to find parts for them. Best of all worlds is the 1977 dizzy because it was small body, and was not a vacuum "retard" smog dizzy.
Downey,
Does this chart from SOR show "build date" based on the VIN?
Bought my 8/77 build new in October of 77. It has small cap distributor with igniter and points. That is what was in your 4/77 build originally. It is the distributor that Downey mentioned. There were changes in 9/77 and I do believe they went to larger electronic distributor then
My Serial number is 255238 and that lands right in the square for 8/77 ( if some one had not typoed that entry look at it --it says 524763 should be 254763---- so it seems chart is pretty accurate.
Yep. I bought my 78 (Sept 77) new in Dec 77 and it has the fully electronic distributor.
The unit pictured is an '80 or newer distributor. Your rig would have come with a points triggered "Semi-electronic" distributor. The electronic distributor first used in Sept of '77 in the beginning of the '78 model year was fully electronic but had a smaller body than the one pictured.
With the exception of the 1978-1979 model year and IIRC the 1974-1975 as well, all the model years start in September of the previous year. A Cruiser with a build date of 9/77 is a 1978 model Cruiser
The electronic distributor of either style is far superior to any of the earlier points style ignitions. They all have vacuum advance and they are sealed and waterproof with vent lines
Mark...
Unless it was a Cali spec 77 and you got points, vacuum advance and retard. Of course you can always block off the retard port or put a BB on the vacuum line to keep it looking oem. :beer:
Do you have the igniter and coil that go with that late model 1981-1987 large cap distributor?
Go HERE to see all the info you would need about that distributor including the igniter you need for it.
That would be an upgrade someone did. Much better than the 77 or 78 Distributor!
I don't remember the whole store, but 1,000 years ago I was told that you could remove the retard hose, but leave it open to the atmosphere, do not block or plug it. If you plugged it then evidently you also wiped out some of the "advance" function. ???
Shoot...I'll have to look up where I read that. I think it was a post by @65swb45 maybe. I wonder if I'd notice a difference one way or the other in mine.
