1975 fj55
Hmm...and I thought I read that you could not have OD and a PTO at the same time...dang....
The split case OD couldn't use the PTO. That's not the case with the earlier one piece case. The earlier three speed OD came with a PTO gear. Then just like Toyota the four speed OD came with a spacer instead. The advantage of the OD is the same PTO gear could be used in the four speed OD while without the OD you had to find a sixteen spline PTO gear to replace the three speed's ten spline PTO gear.:cheers:
I think I may have misunderstood you. Do you have an empty boot too. If so I could use your's too if you want to sell. I've got more overdrives than boots:crybaby:
Sorry but no I don't have a spare Fairy boot. The only boot I have belongs to tha Fairy O/D in the truck - Arnold in my sig line. :D
ok, Pep Boys says the alternator tests fine so I will re-install it and take a look at the wiring. there is osme extra wires in there, I will take out the extras and see what happens. I assume the next step is the voltage regulator?
T
