Build 1974 HZJ40 Build
Yes, Nice work Charlie!
This 3.70 factory ring/pinion has the solid collar built into the pinion shaft.
1961794
The thick .113" shim can be sanded with #60 to tweak in the exact desired thickness.....and I did that 4 times.
1961795
One thick and one thin. The adjusted total ended up being right near .122"
1961796
11 inch/pounds of smooth pinion pre-load.
1961797
Only the best......Marlin seal.
1961798
The oem flange was wet sanded with #1500. It still had a pretty good groove where the stock seals would ride.....but the Marlin seal contacts a point about .200" lower on good virgin shaft.
1961801
DING and this will never loosen up.
1961802
Now to set the backlash and preloads.......
1961803
A nice, solid 9 inch/pounds of carrier bearing preload using 3.7 gears......
Backlash is recorded on every other tooth.
1961876
Being these are front gears with manual hubs I set this one for .005" minimum.
It was an attempt to get the patterns closer to center.
1961877
This is with .044" pinion shim. Looks darn good. These are take-offs so patterns will not be the same as "new".
1961878
Coast is definitely on the toe end. Best possible pattern with minimum backlash.
1961879
Using an ohm meter from the 80's/90's I measured 3.9 ohms across the coil.
1961880
RTV is a good sealer for the rubber grommet...it is a slick lubricator and makes pushing the grommet thru much easier.
1961892
1961893
12 volts is applied to the 2 wires.....
1961894
.....and turn the ring gear a few inches and the 3 locking pins are pushed into place.
1961895
Remove the 12 volt signal and the pins snap back into place(unlocked mode)
1961896
Home stretch..............
Notes taken during the install.
1961906
I think I'll head to Autozone and get a can of that brake caliper paint. Steve Schaefer recently supplied me with a Landcruiser 3rd that he sprayed with the caliper paint and I like the durability and look of it. Better than Krylon I think.
1961907
81 ft/lb and red loctite
1962734
The old carrier bearings had some pitting in the races....
1962735
This other carrier race was actually kind of chromey looking....meaning it was "well worn"
1962736
less pitting on the chromey race.
1962737
The new Koyo carrier bearings saw some Sleeve Lock on the extra clean journals.
1962738
Holy hell, it's freaky how similar our 1HZ installs are... down to the Toyota parts from Pick-n-Pull to complete the intermediate shafts on the FZJ80 steering box install...
Thanks for the tip on the Denso starter motor interchangeability bit too!
Bravo!
Bravo!
Yep. I've been watching your engine build thread for a while, but didn't realize what you had planned for it. The engine turned out super clean and I'm excited to see how the rest of your swap goes.
We seriously need to exchange phone numbers.
Hi Eradicator,
Diff #2 (rear) coming along nicely. Man, these bearings had some deep wear marks.
Toilet paper is very effective for removing oils from the races for close up photos.
outer pinion bearing and race. See the 3 indentations from the rollers?
1963375
easier to see in this close-up. Brinelling. These are history for sure.
1963377
This is the large inner pinion race. Not obvious with this digital picture but it has a very chromey appearance with much pitting. Deep wear. Funny thing is that the rollers look much better ....seems the races tell the real story.
1963378
New koyo races tapped in. 360 degree support of course.
1963435
Might as well start with the same 048 oem shim
1963436
I try to duplicate the same final preload that I plan to at the end.....close enough....11 or 12 inch/pounds.
This is with lots of gear oil on the bearings.
1963437
I'm looking more at the "depth" of the pattern....from face to flank. The toe to heel location is where it will end up
and that can vary alot. It's usually not in the center.
I can see that this means shallow here.
1963440
Coast side verifies that it is shallow.
1963441
Comet tails can offer a refreshing insight.....and it's deep in the root....deep in root of pinion tooth means shallow in the ring tooth.
1963442
yep. I wonder what 052 will look like.....
1963443
039 plus 013 is 052. Micrometers to make sure I am getting exactly what I want.
1963511
Drive side....this could be exact depth or possibly a touch shallow.
1963513
Coast....this is saying a touch shallow.
1963514
comet tail is not harshly in the root. It is saying to go a little thicker on the shim.
I'll try adding .003"
1963515
This one is a slow responder......and that says good things about the way this gear was cut....really good things.
This is with 055 and this is "exact depth" but Charlie will want max strength and quietness so a final tweak will happen....
either 057 or 058 will be the final value.
1963573
Coast is saying I can go deeper....so maybe 058
1963574
The comet tail says that it's getting real close to the optimum value.
1963576
Comet says try 058.
1963577
yippee! diff #2 done....except for a coat of black satin brake caliper high heat paint.
Only the best.....Marlin 27 spline seal.
1965453
Solid collar has been set and lots of anti-seize on the threads to minimize resistance.
1965454
A nice, smooth 10 inch/pounds of pinion preload. DING! and this end is done.
1965457
Caps torqued to 70+.....then dial in the backlash and carrier bearing preload.
1965458
Backlash is recorded on every other tooth. The minimum BL is etched on the ring (.007")
1965459
