1974 electrical grounds locations
Link in my signature
No pics... and mine is far from stock now.
The harness to frame is a white wire with a black line with an eye that attaches to the frame rail under the gas tank on the inside of the frame rail.
There needs to be another wire/cable that goes from the starter motor/block to the frame beside it.
I currently have only 1 ground from the battery to the block (that's how it was setup when I bought the truck) after reading through these threads it seems I need to add a ground:
From the battery to the frame
From the block to the frame in the same location as the battery
From the starter to the frame (this was present but was beat up pretty badly)
sound correct?
