1971 wiring question—mystery wire
Escanaba, MI
Hello—
I’m working on the wiring for my ‘71. There is a RG female bullet that comes out of the harness, passenger side grommet, also where the GY/RW pair comes out and goes to the inspection plug. Any ideas?
Thanks!
Kris
My '71 has the same wire and connector (interior of vehicle), but nothing's connected to it. I believe it's supposed to be like that for the US market. Maybe others will chime in. @Coolerman would have the expert knowledge, especially for the '71 model year.
Good to know--I checked a couple other earlier setups (68/69) and they don't have that connector. I've checked the wiring diagrams (coolerman's too--very good!) and nothing shows.
Hard top or soft top model? Have you checked voltage key off key on? Some where I have 5/71 FHT harness from a cruiser I parted out in the nineties. Also have FST harness from a unknown month in 71 I stripped out of a wrecked cruiser in the late eighties. The FHT had the same emissions as the 72 but believe the FST didn't. Wasn't until later there was a speed marker in this location and that was two wires. Is this wire inside the cowl or outside? I know my 68 and 70 the wires for the inspection plug come off the main harness inside cab and then go thru the firewall to the back of the inspection plug.
It's a hard-top model. I'll check voltage. The wires for the inspection plug _and_ this wire were both found outside the cowl. They exit the wiring harness at roughly the same spot. This is assuming the POs' didn't pop it out the grommet at one point.
My connector was inside the vehicle, not in the engine bay.
That is the hot wire for the soft top dash light switch. It is known on MUD as the Darth Vader light because the rotatable light cover looks like Darth Vaders helmet.
That wire will have +12V on it at all times. It should be INSIDE the cab, not outside.
Excellent! Thank you. I, in fact, had one of those once from a previous rig I parted out, but I bet I didn’t keep it. If I did and find it, I’ll post a pic in a few years. I didn’t know they had those as an option on the 71 models.
My 71 has the hot wire connected to the little switch that is just left of the ash tray, it just hangs out in the glove box behind the hole that is to the right of the glove box. I filed the hole and connected the wire. I did it the cheap easy way.
