For Sale 1971 Fj40 - Fuel Injected - Full Cage - Pics & Video - Locked & Built
Hello All!
I have owned this truck since 2006, The engine runs very strong, power-steering is easy with the 37's, tons of flex, and is relatively low-CG for a sprung over Land Cruiser. Almost everything is new and/or replaced on the truck. The fuel injection makes it a bit more street-able as well as the Saginaw power steering setup (one hand turning) , front sprung-over with recessed shackle reversal keeps it tight and low on the road, extended wheel base helps it track straight as well and a custom sway bar was done to keep in order to keep the truck stable in turns; flexible but still be able to be used heavily on the street (removable swaybar). It has a 4-speed manual transmission with a new clutch and all new brakes all around, 4-wheel disc brakes and upgraded front calipers make it stop well for a truck of its size (replaced/new: brake pads x4, new calipers x4, rotors, hard & soft lines all around, upgraded brake master Cyl.). Battery is fresh, all new professionally built TBI wiring system with all new sensors, injectors, computer & custom tuned chip make for a healthy and great sounding/running engine with the single exit 2.5" mandrel bent exhaust (flowmaster 50 series). Well built cooling system for Florida with a aluminum race radiator, high speed cooling fans, all new belts/hoses and fluids always kept fresh. I can help load for shipping / transport if need be, just contact ahead of time to arrange it. Its 40+ years old so its not perfect and if your not mechanically inclined, I wouldn't suggest a 40 year old truck. The FJ40 has all new floors, sprung-over, 6-point roll cage, front bezel hoop & rocker protection, so its built for off-road but could be daily driven, please email/message if you have any questions. Comes with spare 37" MTR on a 15" rim & Hi-Lift. This truck was never abused on the trails & mostly driven on the street, stowed away in my garage here in St. Augustine , Florida (32080). Seats are brand new and have never seen weather, as well as all new thicker then stock floors coated with 2 coats of RustBullet and 2 Coats of Duraback. RCI has sump for steep inclines and the new TBI makes the truck sound and run very well. I'm selling off my Toy to finish adding onto my wood-shop, the Fj40 will be sitting in the garage collecting dust until its sold... Any questions/comments/rants email or message me here...Might need minor cosmetics here and there, remember its a 40. Please no low ball offers, I feel as though I have already made the price reasonable for the truck you'll be getting...
Engine / Powertrain
  • Rebuilt 5.7L Gm 350 with 85K +/- with stage-1 TBI fuel injection
  • RV Cam
  • Edelbrock performer intake - (All new fel-pro gaskets)
  • Rams-horn exhaust manifold - New Gaskets - Walker crossover exhaust - 2.5" Single exit with 50 series Flowmaster
  • Full billet aluminum pulley system
  • Fabricated aluminum valve covers
  • Replaced long water pump, alternator, power steering pump in last 200 miles
  • PSC power steering lines to Saginaw power steering system
  • New Battery - mounted underneath pass. seat
  • New starter
  • New USA-built Sanderson aluminum racing radiator
  • Taurus Cooling fans - Adjustable thermostat
Fuel Injection
  • Rebuilt TBI - Every single sensor is new:
    • AIC, Temp. sensor, knock sensor, oxygen sensor, throttle position sensor, electronic spark control module, etc.
  • Professionally built TBI harness
  • 15 gal. RCI fuel cell with sump
  • Stage 1 pro. tuned chip - Runs on reg. pump gas
  • Brand new GM ECU with new chip
  • New E2000 Fuel pump / filter
  • New coil
  • New Distributor - new cap, rotor - 8mm Wires, AC Delco Plugs
  • New fuel pump relay and fuel injection relay - ECM, relays and ALDL connection is all in the "glove-box"
Transmission / Transfer-case / Axles / Suspension
  • Sprung-over - Kept flexy and low as possible for a fj40 w/ 37" tires with a front shackle-reversal
  • Sm465 - with granny-low first
  • 3-spd Toyota T-case - with ~65:1 Low
  • Advanced Adapters - T-case/trans adapter and mount
  • New clutch - less than 150 miles
  • Willwood Slave cyl. - New Toyota Master cylinder - Kevlar braided clutch line
  • Prof. made custom woods drive-shafts
  • Custom front-sway bar
  • New Aussie Locker in rear (no trail use)
  • Billet hysteer arms - Rebuilt front axle
  • GM 1-ton Tie Rod Ends - DOM .5"wall Tie-Rod
  • Upgraded Forerunner Calipers with new pads/lines
  • New Forerunner 1" Master Cylinder
  • 4-wheel disc brakes - Rear disc brakes with Summit prop. valve - all lines replaced
  • Bilstien 5150 remote res. shocks in front
  • New Monroe rear shocks
  • 37" Goodyear MTR's - Front driver is new (>100m), the other three have good tread but have "rock rash"
  • Spare comes with vehicle purchase
Interior / Exterior - 99% rust-free
  • Solid metal, no hidden rust holes
  • Painted sunrise red , random knicks n scratches
  • No hardtop / softtop - easy enough to obtain though
  • Custom Roll Cage & Front Hoop, all 1.75" OD - HREW steel
  • Brand new - Race trim seats - Fixed mounting
  • RJS - 5-point racing harnesses
  • Dash cluster has tachometer, vacuum, amperage, water temp., oil temp.
  • Upgraded Headlights - runs newer style brighter bulb
  • Floors - all floors have been replaced by with new non-stock sheet metal and RustBulleted, painted & Duraback'd -
  • Front bib/bezel has rust hiding in there, that is all - truck body/exterior is highly modified & is solid
Odds
  • Needs windshield wiper assembly & their is a hairline crack in the passenger portion of the windshield if you plan on daily driving it. ( I can pick one up locally for $ )
  • Turn signals were wired into the marker lights because of fender removal, still has wheel-wells, just the lip was removed. Street Legal!
  • Comes with 4 keys and clean Florida title ( spare 37" MTR & Hi-lift Jack too)
Price: 7,500 - I consider it a very fair price considering how 'overpriced' fj40's can become (Not open to trades at all unless you somehow have a mint Diesel Mercedes & Cash)
Here are some pictures:
Last pic shows only rust issue on the truck, It is the lower section of the front bib, There are no hiding rust holes anywhere, this is again the only metal that would need an eventual fix, the main body and new floors are all coated in Rustbullet & Duraback...
The frame is in good shape, rear is boxed in for rigidity and a new crossmember was added for the shocks, wheel base is extended about 8" over stock which makes it a bit more stable on the road & amazing approach angles off..
Just one note for long distance buyers:
The seat height from the bottom of the seat to the bottom of the roll cage rail is 36" (So measure from your ass to your head, lol). The Roll cage was designed to work with both stock hardtop and aftermarket soft top. Seat mounts can be adjusted if need be. Everything was kept low profile to ensure that you could put a hardtop back on their with a negligible amount of room.
