1969 Carb Question
Golden Colorado
I have the 1969 Carb that was manufactured for 6 months - So far it seems I'm missing this linkage - Does anyone have one or any ideas on who may have one?
I'm guessing you will end up making or modifying one. Look at other carbs that have a vacuum bellows.
Scaling off a printed picture can help get the size. Pick a part you have and can measure, measure that part in the picture.
I have looked for about an hour on line to see if I can see that part in a picture on my 03/69-09/69 carb and I can’t find a picture anywhere seems it is always blocked in a picture
Maybe someone has a picture they could post of that part
I have some other links from other carbs I could modify if I had an idea
Thanks
That's the same carb from what I can tell - Your picture is what I was looking for
I have rebuilt and re-adjusted the float many times
The float on this one (mine at least )if adjusted to the recommended 6mm gap will allow too much fuel in so that took some time to get it to the fuel line
What does that diaphragm and linkage do? Do you need it? There was a similar diaphragm on my 10/'73 called a "throttle positioner", I didn't think it was needed so I took it off. But if it's for your secondary, I guess you might need that...
Could you mock up a piece of coat-hanger wire to see just what shape and size you need? Some people have left-over carb bits that might be close.
PigHead Toyota Parts Warehouse!!!
I have a link you can have for free…with a $100 minimum order.
