- Joined
- Aug 18, 2008
- Threads
- 17
- Messages
- 1,686
I'd go with gas problem first. I sometimes forget to adjust my flow on mine and it will splatter and be nasty.
Are your rollers coated with a film? causing it to hop? might try checking the tension on the rollers by the spool that feed the wire thru the gun. then check depending on machine the tension on the actual spool. if all that fails check your leads for something loose. the ground clamp might be loose? or the hot to the gun might be loose. What machine? 125 Lincoln from Home depot or welding shop? It's my understanding the home depot version has plastic rollers and the welding shop has steel.
. I found a Porsche project, or should I say it found me. Total Barn Find. 1968 912, 3rd owner, original books records, window sticker etc. Same owner for 33 years. Sitting in his garage for over 10 years. Every single option listed on the window sticker is still with the car and it has not been molested. Very rare to find a Porsche that has not been hacked on. The PO was a Porsche mechanic and did things right until he had medial issues and parked the car. ....
Here is the thread I started on Pelican.
Garage/Barn find - Pelican Parts Technical BBS
.. I just have never liked them on the 901 body,...
Peter, maybe I looked at a different catalog? The one I thought you referenced was a complete parts catalog. Can you send me that link for the "Original Parts Catalog" you mention?
Yes, I too love the look of the Through the grill fogs.
check out my latest Porsche progress here.
... but the Porsche will probably still be going. Though the rust repair and metal work is almost 100% completed. At least something is rust free.
Generally, a pretty fair amount of chat is overlooked in these forums, but there hasn't been a post on subject in some time now.
