1964 Trailblazer Chief Camper Build
Got the holes cut for the sink and stove. Will probably work on the finish in the next week or so and hopefully get them both fully mounted and the counter in the camper.
Picked up a tongue box and mounted it. Also picked up a propane tank, which I had intended to mount in the tongue box but its to tall so I'll be mounting it under the counter somewhere instead.
Also got my awning mounted after it sat in the garage for about 9 months.
Also built a rock guard for the front window this weekend. I used some angle aluminum to make a frame and inserted the old decorative shutters from the original camper.
Painted it a nice flat black to match everything else. Added a couple locking hinge arms to keep it open when parked. Really pleased with how it turned out and its super lightweight. Still need to come up with a latching mechanism to make sure it doesn't fly open when driving.
Took the camper out for a little shakedown run. Only went about 30-40 minutes from the house but it was good to get it out, see how it towed, use it and figure out what little things need to happen before a longer trip later this summer, and it got rained on and I didn't see any leaks. It seemed a lot bigger when it was filling my entire garage but seeing it outside and near modern campers made me realize just how small it is. My wife named it blueberry after seeing it in the wild.
You did a great job on that old trailer and it was fun to follow along from the beginning and on to you and your wife actually getting to use it. I'm glad you guys got to finally enjoy it.
Spent time getting the gas tank and water heater into the camper this weekend, mocked it up and played with the locations then mounted everything.
Tested the stove and didn't burn the thing down.
I didn't think those propane water heaters could be mounted inside. Do you have to run an exhaust or anything for it?
You can mount it inside as long as the 4" port on the top is vented to the outside or you have enough airflow. I will be venting it this week/weekend. If I get in a pinch and don't get that done I could just open the windows and doors and have enough air circulation though. I know the exhaust gets warm/hot but I'm not sure exactly how much so, will probably go with a double walled vent pipe.
Pulled the camper out of winter storage and picked back on on getting all the water system finished. Shower drain is in, plumbing connecting the shower drain, and sink together with the quick connect for a portable take is in. Still have to fill the holes with spray foam, add some additional support, and waterproof to button it all up.
