17mm Pin
Panamá
Website
www.4x4panama.com
Hello all ..
I know .. 40 / 70 ( pre 90 ) and 60 series knuckles use 17mm pin .. Marlin offers an upgrade for us with 25mm pins and corresponding bearings ..
Which it's the size on the 80 series knuckle ..?
cheers,
David
If you mean the ID of the trunion bearing hole the 80 is 20mm.
Bigger pin diameter means smaller bearings, unless you drill out/change out the knuckle ball. Have not heard of the stock 20 mm pins being prone to failure. John
I was thing in something like 25mm Marlin upgrade for 40 / 60 series ..
