17 x 8 rims for 200 series cruiser
I need your advice, where do I get a good choice of rims from in the USA for Toyota LC200 series?
I want 17 x 8 +60 offset from what I've read, in steel. I plan on running 33" KM2's,
Any feed back would be great.
Barn
2012 GXL TTD V8 cruiser
Good luck.
I did a search a while back and couldn't find anything that met those requirements. Went with steel OEM 18" instead. Painted them black.
Consider 17" TRD rims. You Toyota dealer can get them for you.
The +60 offset is for original tyre size
I run maxxis BigHorns 33s and have +30 offset
No rubbing inside or outside, with 17x8 KingWheels
Hope that helps
I have the 17 x 8 TRD rims - they are a +50 offset. No problems at all with the Toyota recommended LT285/70R17 BFG AT T/A KO's at 32.8":
:cheers:
This is the wheel you are looking for.. but I don't think you'll find it in the US. Where's your location?
42611‑60630
KingWheels in Australia make a steel 17x8 +30 offset. I have them
Toyota Australia sell specific 200 17x8 Steel rims like the photo above. I bought a set for my muddies. Depending on the model, you can get the 200 with 17" steel, 17" alloys or on the top model 18" alloys. The 17" wheels fit all models. They are 17x8, P60
The steel rims are about $110 each from a dealer. The issue here ( Australia) is that you have to get wheels that are rated at a minimum 1250kg like the originals, not many after market wheels are rated that high.
I have been looking for good looking wheels forrever for the 5x150mm lug pattern, seems they just don't make the basic looking black rock crawler rims or anything close that I have been able to fine, with so many rigs now running that wheel pattern I would think the wheel choices would start to go up...
I did some part cross referencing this morning on Toyota 17" wheels (ie, not Rock Warriors).
This partsouq page has most of them on it, at least from the steel side.
Here's the part numbers:
I'm most interested in the 42611-60A60 or 42611-60A61. Attached is a picture of the 60A61 variant.
As far as pricing, they're inexpensive - like $100 / wheel. The shipping from UAE and AU is more than the wheel cost. . .
Did you run across OE center caps or were there none or you didn’t get that far? I found these 18” rims Steel Wheel, Rim 18x8 - 69512 It seems they have 17’s too, all Tundra OE replacements
EDIT: OMG! Raised from the dead. I just saw the date on this thread. I have no idea how I got here... I was probably searching steel rims inspired by @FlightMedic178 rims and I’d want 18’s as the 275 in 33 is what I want.
Nah, I just continued the discussion, no need to make a new thread when existing are around.
I didn't look into wheel caps; but the part numbers exist so they are available. As they are light they could probably be sourced much more cheaply. Air freight on wheels is a killer.
18" tundra phone dial steelies are reconditioned on Amazon around $65 each.
I'm after 17", narrow if possible. Looking to put 35x10.5x17 on them.
I especially like the 10.5 aspect of your quest. People underestimate the amazingness of tall-skinnies aired down. The square inches of contact goes way up and when rolling down they road inflated the roll pretty easy and resist hydroplaning.
I have a quote including delivery for 5 42611-60A61 for $715. $103/wheel and $200 shipping.
$40/ea for shipping. That’s cheap.
Pretty competitive, yep. I'm still not decided I'm going down this path, but I do love steelies...
Let’s see, a uk site I think called Toyota original, and one of the Middle East sites, not partsouq, their shipping is all by air. Had to reach out to both to get the shipping quotes straightened up.
