That trohpy truck statement is stretchin it. My rig is simular to a KOH type of rig, not a trophy truck.If hes building abudget minded somewhat normal rig (not a custom/hardcore) why is he asking for advice in the hardcore corner?
He asked this in the hardcore section, so I assumed he was after hardcore advice not justification to run a cheap heavy huge pig.
If you are a broke ass noob with a mud rig then a 14 bolt is fine.
No hate, just pointing out another option.
I dont want a huge diff with not many gear choices, that weighs over a 1/4 ton.
personally if i was going away from yota axles and had tires smaller than 42's and felt like the 14 bolt clearance was going to be bad then i'd rather use a ford 9" over a 60
35" tires are hardcore?
The problem with a ford 9" is the housing. If you are going to opt for one of the Bling housings, then you'll be good. But a factory housing is not up to the task. unless you weld about 300lbs of metal to it..
I am a fan of the 9" tho.
This thread just shows why i won't ask any questions here. I love the info that can be found, but i think it can confuse as much as it can help.
So, what are you confused about?
Too much B.S. over a 14 bolt.
but thanks for asking.....
It is the Gold Standard of wrecking yard axles and you will still have money left over. If the ground clearance bothers you, shave it. I'd take it any day simply because it is crazy strong and easy on the wallet. Is there something more important that those two factors? I have yet to meet any woman impressed by anybody's choice of rear axle hardware so it can't be that...
I went with the semi floater 14b because its all I really need, its stronger that the LC axle, I needed a centered rear and it comes with six lug shafts. Eaton also makes an E-locker for it which I have been really enjoying.
I agree that a 14 bolt is great for the money and very easy to find.. just seemed to me that the discussion got overly opinionated about something that is a pretty simple choice to me. When i swap the BBC into my 60 in the fall i will be installing one.
you must not be dating the right women...
sorry if i offended anybody with my sarcasm...
I
Son of a B!+c4 ! I just sold my 35's a few months back! Now my tires are to big!!35" tires are hardcore?
They are the new 40's![]()
