THANK YOU!..
An on/off switch SOMEWHERE.... depends on your compressor placement and intended use... and tank size (how long to fill)
If you are just filling tires at the end of a wheeling day the switch can be anywhere.. you will be stopped and out of the truck. if you are using it for lockers you might want to be able to switch it on from the driver's seat.
I've got a switch on the dash, the wire from that switch goes 'through' the pressure switch to the relais that provides the compressor with power.
When I flick the switch the compressor starts running. When the pressures builds up to 8bar or so the pressure switch interupts the power to the relais and shuts off the compressor. When pressure gets below 5bar or so it switches back on.
Works very well..
In hindsight it might have been better to put the relais in the ground wire instead of the positive wire. If it makes any difference at all that is.... dunno
