who are you and what have you done with spressoman...?
Another one from Handpresso:
http://www.thefancy.com/things/336885666564543005
You generate a 16-bar pressure as with a bicycle pump, add hot water (from a kettle or a thermos-flask), espresso coffee (E.S.E. pods’ ease of use), and prepare a high quality espresso! No battery, no electricity needed: just perfect for those who care for the planet!
Water reservoir of 50ml
Very compact 22 x 10 x 7 cm
Light weight 476g
IMO the Areopress is the best on the market. The handpresso is a close second. Everyone here is quite happy with the Jetboil system which is good but I think the MSR Reactor is a bit better. The Jetboil you can hold in your hand while boiling, but the Reactor is more efficient and allows you to use 3 different pot sizes. MSR now has reshaped the 4oz isobutane cartridge to fit inside the pot on this stove.
The Aeropress is hands down the best coffee maker in the world. It's all I even use at home now. It makes typical French press taste muddy in comparison.
To OP.I consider myself a coffee snob --- I calibrate my espresso machine for each batch of coffee and changing weather conditions. I think pod systems are scams. Can't you tell I really don't like pods?
Pods make so-so coffee. Their coffee grinds are not as fresh as freshly ground beans and they offer much less variety than store-bought beans. They're relatively expensive, and they create alot of non-compostable, non-recycleable garbage. I recommend staying away for them.
IMO, there is no need for a 12v coffeemaker. You can get a superb coffee experience with some version of the following:
I would argue that the good old plastic coffee cone and fresh-ground coffee will offer a more satisfying experience than pods.
- Porlex hand grinder (or equivalent)
- Aeropress or a decent French Press or Moka Pot
- A good stove to boil water.
