My hj61 has plugs that are unused from factory. Was it on starter motor side? I have plugs on that side not user
I have just started work so ill be about 10 hours till i can have a look for u
Sorry i know its longer than 10 hrs but just finished work and its pitch black out. So prepare for crappy pics. The three unused plugs i have on the right side of the motor next to starter are as follows
That black red wire is used in auto,s it is the neutral switch, with a manual is not needed
Does it get cold where you are? Im in south australia so the coldest i see is 0 degrees celcius, my glow screen isnt hooked up and she fires up within half a turn, love compression fire
If ur not extremely cold u may not need it straight away, could get you on the road quicker
You may already know but that plug harness will require a plug loop as in the photo from Niffa, I just did a conversiôn myself, as it needs to loop back to itself to complete the circuit for starting
Enjoying your thread, look forward to seeing more of your good work
I may have missed something here, but did you say this motor is a JDM, indicating it's a 24v 12HT ?. I'm just thinking out loud, did you swap the starter for a 12v starter, or have the original 24V starter still attached ?
