12 ton jack stands arrived
Sorry to pull this old thread up, but I got a set of HB 12 ton stands for christmas and I don't want to hash the whole HF debate, just wondering if anyone has any input on these. For the $$ at HF no less, and based on the shear mass of these things, I can't believe that these wouldn't be good units.
I found a good bit of info on 6 & 3 ton, but not much on the 12T's.
I will likely pick up a second set of 12Ts of some flavor to have a set of 4 with some christmas $$.
Thanks,
Tucker
X2 - I have nothing but good to say about them.
safety is good
12 ton stands for a cruiser is clearly overkill. Not that many (many!) of the things we do on this forum aren't overkill, many are, but... 6 tons per stand is still a pretty solid 5x safety margin.
Just to stir the pot a little: if you are really trying to be super-safe, it would probably make much more sense to use 2 jackstands ( you could get away with 2ton) on each corner vs. 1 big one.
Finally: I see a lot of safety ignorance down here. It is as if local mechanics lead a charmed life. One of the things that I point out all the time to them is that chocking AND blocking the wheels you aren't working on is pretty darn important. Even if you have a 12ton jack stand, it isn't going to hold if the truck rolls 1 foot back or forward.
i was about to get under my 40 (two jack stands supporting the weight of the rear end only) i have the collapsed jack stand sitting my my computer as a reminder of how lucky i am. they are the GM performance parts 2ton jack stands. :mad: when one failed (collapsed in on itsself the vehicle rocked falling off the other one... lucky for me it failed at almost the second i let the jack down so i hadnt had time to get under there yet. it was the first time id used the jacks. the box was still next to me :mad:
I've been using those exact stands for years without any hesitation. I'm actually thinking of getting a second set.
Thanks guys that is really what I figured, just needed to hear it from some fellow mudders.
Thanks again,
Tucker
