100 series parts, 98 gray interior, 99 tan interior part out
South KC
Some how I ended up with 2 100 series parts rigs. Let me known what your interested in.
98 body is gone but still have both rear doors, gray 2nd row seats, and a lot of grey interior parts.
99 body is rusty from MN lots of good interior.
Drivetrains available from both. 258k in one 335k on the other.
The 98 I stripped every nut and bolt off of the interior and exterior. Not sure if the 99 will be the same way due to rust.
I think that I still need the electrical harness plugs going to the transfer case.
Should have what you need. I should have 3 of those now.
How is the drivers seat in the 99?
Driver doesn’t look great one tear and discoloration. It might clean up with leather cleaner. Everything works.
I'm looking for a drivers seat electric motor. the rear up/down on mine doesn't work.
I'm looking for a tilt motor and the driver's side cargo area panel (the one with the tool access and sub cover)?
Tilt motor of seat or rear window?
Should have the part for tool cover. $30
How much for the shifter assembly console cover (i.e., the large black plastic cover that includes both holes for trans and t-case shifters, etc.), as well as the front passenger seat bottom? Shipping would be to 85282.
Sorry, I wasn't specific enough, the tilt motor for the steering column if it was equipped that way.
these didn't have that option. i think that was newer models. you might be able to convert to manual column? not sure if that is a thing or possible.
I’ve got 2 both would need some cleanup and old wood removed. $50 shipped. Or I’ll clean them up for more. It takes a bit to remove all the adhesive.
I think the 06 has a different dash shape. So trim would line up. You have the Tesla style screen option. Seems like they are working quarks out of the system and they are becoming more plug and play.
