100 series master key thread
Here's what i did to program the immobilizer
Get in the truck and close all doors
Insert your CURRENT MASTER key into ignition but do not turn, just stick it in for a second then pull it out, repeat this 4x
Then insert the CURRENT MASTER key into ignition and leave it there
Next open and close the driver's door 6 times, you need to open it enough to hear the little chime ding ding
After that remove the master key, you should see your security light to the right stay solid red. That means it's ready to accept a new key.
insert your eBay key that you just had cut and just leave it there. The solid red light will now start to blink to program the chip in the new key. After 40-50 seconds the light will stop blinking and then you can remove the key and re insert to start the vehicle. If the blinking light doesn't go away, then you got a busted chip or wrong key.
After all the different programming posts I've found, this is the one that has worked. The issues I had above were fixed by this process. Thanks a lot!
I have repaced both my original keys due to breakage. One is a master key and the other shows up as valet. Can I use the master to turn the "valet" into a master as well?
Yes, via techstream its easy.
I programmed my master fob to work. My valet is a replacement key. When I go through the programming steps, everything works until the end. I hold lock/unlock 1 second, release, then lock for 2 seconds. The door locks, then cycles twice and the fob still won't work. Any suggestions?
There are a lot of posts about this. I am going to try to make one thread with all needed key information I can think of. I am not much of a writer so I will try to explain the best I can.
Our 100 series Land Cruisers and Lexus Lx470s all have an ignition immobilizer. What this system does is cut off spark and fuel to the engine unless the correct key is used to start the engine.
There are 2 different kinds of keys, a master and a sub (valet) key. To add new key codes into the ecu a master key is required to allow the ecu to enter programming mode.
If all keys are lost the ecu will need to be reset.
The best way to tell if your key is a master is to watch the security light while you insert the key into the ignition switch. If the light goes out as soon as the key is inserted you have a master, if it stays lit for a second or two your key is a sub.
I think it is ok to advertise my services here. If not someone please let me know.
Here is my little ad for flashing services:
Do you still provide this service, and if so, what is the cost? 2001 LX470 with only valet key.
Late to the party sorry, need assistance. I have a Japan spec 98 uzj100. I have a key of this sort, and I need to get a new fob as a spare. Was looking to get the newer model fob with the 2 buttons, how do I get to program it, if I can? As non of the key guys know what needs to be done to this sort of key, apparently no one has seen this type of key on an LC
Did you ever find a replacement key for the jdm 100?
I have the diesel version but its a non transponder key. I don't have a spare and would like to find one.
FWIW the jdm 80 series key looks the same as the 100.
Anybody have a line on jdm keys or where to get them cut?
No where local has a clue what Im talking about
Wondering if anyone can help with the immobilizer reset (all keys lost) process. I bought my 2004 LX a year ago with just the valet key. I recently bought a new key to program as a master, even made sure to acquire the correct 67-tp29 chip.
I’m using techstream v12 with a 1.4.1 cable, connection is stable and consistent, tested with comms to all of the body ECUs. I also have a battery maintainer hooked up to keep voltage consistent during the reset. Driver door open, valet key in ignition switched to “on.”
My problem is that Techstream says “immobilizer code reset has failed” - popup message below. Does anyone have insight into this step, and can you tell me the combination of steps it takes to solve? If it helps I can pat my head and rub my stomach at the same time, so I’m pretty much a pro.
I am now in the process of getting a new key made by socal costco parking lot vendor (pay in costco, the cut key in van).
done this before w/o master key (I have 2 of those tucked safely away).
I'll report back when i test it (got to the van too late as they were there for 1m and blew thru all their)) toyota blanks :bang: ).
