1/4 eplitcal suspension???
If you want to do that then go ahead..
I see no reason to add complications like that. Additionally, you would need one hell of a wheelbase for that on a full bodied rig..
BTW, stop using caps in the first letter of each word you use. It is getting obnoxious :flipoff2:
Um i'll try to force my self not to type in caps.... but, the mounts can be anywhere, i'm planing to move my axle back 4-5 inches for longer links, and i can put the end of the spring farther forward on the frame ith a side mount bracket... t should'nt be to hard, i still have my stock rear springs...
hey man post a new pic!!
this past Sat i got a 1989 Fj62 as my dd so i can build my 40 up even more im looking at a 4 link
or
just turning the springs around for now, making the wheel wells taller and wider in the back, S/R the front and do 4.88 gears, but both i have to save for!
glad to hear the NEW plan cam:grinpimp:
this sounds like it's going to be a lot better.
so how long do you think your links are going to be now??
i'm at 101" and with the new 40" MTR's the tires are about 1 inch behind the bumpers, my approach and departure angles are almost 90*.
112" is gonna be a loooooong truck;) lets see the pics when you get them
sorry to be a dick, but this plan sounds a lot more thought out and BEEFY:grinpimp: BEEFY is good, right?
I Not Sure On The Links Yet How Long... Old Ones Where About 3'9".... My Rear Aproach Angle With Mock Up Links Is 90* With 35" Tires... I Plan On Runnin 38.5" Creepy Crawlers So I'll Have Really Nice Departure...
I Almost Done With Top Monut Brackets On Axels Links.... I'll Need To Get My Engine Set In Before I Do My Front Brackets Of The Frame...
I Hope To Get Some Pics Up Tomorrow...
Niner said:
I used 1 1/4" OD X 5/16" wall DOM tubing ,then you end up with a .625 ID and you can just tap it for 3/4" fine thread.
The Only Problem I Have With That Is If It May Happen The Heim Yanks Out Of The Pipe Ruining All The Threds... There For You Need A New Peice Of Pipe... Weld In Insertd You Can Just Cut Out The Insert And Replace It Other For About 10.00$ Instead Of Have To Buy New Pipe And Det It Threaded Again....
Just Trying To Think Long Term....
Full_M3tal said:
Ok So I Sold My Rollbar, Got 110$ Out Of It... Hoped For More... But Thats Ebay... Did Loads Of Research On Mud/Pirate And decided To Cut Of All Of My Link Mounts And Re-do Them... Im Going With 2 1/4"(2.25)
KREW Tubing 1/2"(.50) Wall, 3/4" Weld In Inserts,
And A 3/4" x 3/4" Jimmy Joint... Inserts And Joint Im Getting From Rocklogic...
:whoops:
Sorry Did'nt Do The Math Right.... Size HREW Will Be 1 3/4" (1.75) With The 1/2 Inch Wall.... No Way A 3/4"(.75) Will Fit In A 1 1/4(1.25) Hole:D
Full_M3tal said:
...Did Loads Of Research On Mud/Pirate And decided To Cut Of All Of My Link Mounts And Re-do Them... Im Going With 2 1/4"(2.25)
And A 3/4" x 3/4" Jimmy Joint....
Glad that you came around and 'saw the light.' Now you just need to get some updated pics! :grinpimp:
If you pull the heim out of your links you have more extensive problems than rethreading the link..
45" links are plenty long IMO.. Don't forget, the longer you make 'em, the stronger they need to be in order not to bend when you put weight on them while sitting on a rock.. not to mention that they WILL find their way into the rocks more often, because they hang down more...
Just my $.02 again..
OTOH, where you wheel, a looong WB may more than offset the downsides.. around here, at 101-ish on 38.5's, I don't wan't to go any longer.
There is a differance in the diameter debate, Mine is 4 linked in the front and rarely have to drag them over rocks like the rears in yours Woody
Never had a problem with ruining threads, the heim breaks before that happens
Fronts typically see less stress than the rears..
Niner, can you post a pic of your setup?
It is in storage and I don't have too many good shots of it, but I'll look.
When I did mine doing the front of a vehicle was unheard of and little info was availible. Street rod guys where just starting to get comfortable with the idea.
Can't really see anything, I'll have to get some photos, alot of folks ask for them.
woody said:
Bring 'er out Sat, I'll shoot a digi or three....
Its resting at Stevies, I don't want to disturb the inside storage deal I have over there. I'll get some soon.
More pics of the girls on the wall please ;)
Haven't lived in that house since September '04. Thats why the 40 is stored elsewhere. :D
I wish the new house's shed was done.:crybaby:
