06 GX470 Coolant Leak
Pensacola, Fl
I have a 2006 and replaced the radiator but still have a leak? Any help or advice would be great as my mechanic is at a loss. A coworker has a LX470 could it be the heater hose T's? Thanks for the help.
Seems like a coolant leak would be pretty easy to find...look for the wet spot? The rear heat comes from the front through vents under the seats and up to the top vents. Not sure if there are rear line (really don't know).
given there is a rear AC (no heat) I don't think you have a heater line.
Focus in the engine bay. If you want to get snotty, go to another forum :P
You could also get a mechanic to put dye in and use UV to find it fast. Lots of options, none are GX specific, general mechanic stuff.
