Backstory: about a week ago we got 2-3" of snow here in OK, my son and some of his friends romped around in the snow/mud for a few hrs. The 03 LX was completely covered with mud/grass/snow but no "submerging".
At the end of the day my son was taking his friend to drop off, trans started acting funny, wouldn't go into gear. Pulled it home with Dif in neutral (no weird noises, p0771 code)
Next morning trans functions almost normal, but doesn't shift right into overdrive, eventually throws a different code p0776? Drained the pan and refilled with = fluid, fluid is red, pretty normal looking.
More intermittent symptoms, not driving truck more than 2-3miles in town. Got a p2714 once (fluid pressure control ?)
Take it to Toyota dealer: cleaned electrical connections, can't improve symptoms, now shifts into park, neutral, reverse and 1st-3rd. No 4th or 5th/OD.
Dealer "its been submerged, needs a transmission"
Drive home, 1-3rd, no perceived slipping, no lights. Driving at 50-60mph and 3000ish rpm when you let off throttle RPM drops to 1k....is that normal or should the rpm's hold? Maybe Over analyzing...
what to do??? complete fluid change, drop pan and replace/clean filter? change or clean/check solenoids?
help...
help...
