‘01 LC idiot lights
Virginia Beach
Hi I’ve been throwing parts at my truck and I’m getting tired of it. Most of it was needed suspension but I’m stumped with the idiot lights.
1.) C1340 Center Diff Lock that seems to trigger the VSC lights. I’ve replaced the switch with no luck. Old switch also tested good. VSC light occasionally clear themselves.
2.) P0171 and P0174 lean banks 1&2.
-I’ve replaced all 4 O2 sensors, Maf sensor, fuel filter.
-A smoke test revealed a crack in the plastic intake so I epoxy it. No leaks found after.
Thanks for the help.
Hello B1oodyBuzzard,
Check out this thread.
Hopefully it helps with the 2nd issue above.
Good luck.
Tom
Good job finding an fixing vacuum leak.
I would:
  1. Monitor fuel trims, while driving on HWY. See if LTFT runs rich and STFT run lean: While steady at~2200 RPM & ~65MPH on flat HWY.
  2. Do a fuel pressure test, by the book (FSM).
If fuel pressure regulator not holding pressure in rails. You'll not have enough fuel pressure in to injectors.
Did fuel filter backwash, look bad? If so, that's a clue of bad fuel.
If fuel pump weak. You'll not have enough fuel volume/pressure in rails to injectors.
I have a 2006 LX470 w 215K mi. So I was getting the same codes switching back and forth with the VSC OFF light on while the mechanic was driving around and it didn't make any sense. Checked for vacuum leaks and nothing. Engine checked out fine. Cleaned out the MAF sensor and changed the air filter and cleared the codes and seemed to be fine. But when left to idle for about 10 minutes the code comes back and the VSC and engine light comes back on. Mechanic thinks it's an ECU problem not a mechanical problem. UNTIL a few days later the car wouldn't start all of a sudden. No crank just all lights on, no click. Then tried it again and then after trying twice it finally started with VGRS light on. Drove it around to reset VGRS and it went away.
So I did something that I should have done the first time I started having this issue. I checked the battery charge and lo and behold the standing charge was below 12V. So I read that a low battery tends to cause phantom codes because the LX has a lot of power hungry components. Changed the battery and so far haven't had any issues. So crossing my fingers, but the car is running smooth for now with no weird codes popping up.
if P0171 and P0174 lean banks 1&2. in 06-07 100 series. Likely fuel pump.
You may also have a loose battery connection. Or perhaps a bad battery or alternator. Whenever battery dead, disconnected or too low. VGRS lights comes on. Drive in a straight line up to 25 MPH. VGRS light blinks and goes off. Make both right and left turns (I do figure 8). This recalibrates steering wheel in VGRS systems. (Read your LX470 OM)
Finally replaced my fuel pump and it returned after a day
The question now becomes: Why did it crack and is there still a leak and or internal damage.
May be best to R&R intake manifold.
DM me, if you need an intake manifold for 06-07 VVT (plastic)
What returned. Lean fuel condition. Where engine stalls after running in high RPM or what?
After replacing the pump, vsc lights remain constant and won’t let me clear the diff lock code. After a day of driving the check engine light came back, same codes for lean both banks. Engine does not stall or misfire.
In the meantime I suppose I’ll hunt for more vacuum leaks.
