Build Project: Colonel 1979 FJ40
Pendleton Oregon
Website
www.oregongrain.com
I'm going to document the build up of our 1979 FJ40 into a trail rig that still maintains the stock look and feel to some degree. The completion date for this project is July 14th. I need to have it done so I can go on a weekend wheeling trip with the local Seattle Cruiserheads. I started a list here and will ad to it as I'm working on the rig.
Reason for choosing a 1979 FJ40
- Fine Spline
- 22 gallon tank under vehicle
- Lower seats for us tall folks
- Bolt on OEM power steering
THE VEHICLE
Nickname: Colonel Mustard
04/1979 FJ40
Desmogged 2F
Stock Transmission
Stock Transfer Case
3.73 Gearing
Disc Front
Drum Rear
Manual Steering
THE PLAN
engine
Non USA carburetor (complete)
Non USA distributor
Tune Up
Dual batteries (complete)
Re-route exhaust
suspension
SOA front
Crossover steering
4 link rear coil
Rear discs (complete)
FJ80 master cylinder (complete)
OEM power steering(complete)
Rebuild center arm
Front Toyota E-locker (complete)
Rear aussie locker (complete)
4.88 gears
armor
Metal Tech family cage (complete)
HFS winch bumper (complete)
Rear bumper w/tire carrier
accessories
Warn 8375 (complete)
In cab winch controls (complete)
Seat belts(complete)
Tuffy console(complete)
Radio(complete)
Speakers (complete)
CB (complete)
CB antenna (complete)
Rear tailgate (complete)
Air compressor
Air tank
Starting with the rear discs and locker. Loosened all the 14mm bolts and popped the cover to drain the fluid. Installed an aussie locker in the rear. The C clip is a pain in the arse, but you can use a popsicle stick or a large paper clip to help you. Remember to take your time and have lots of rags handy. I used a small screwdriver to compress the springs as I installed them.
Photo of the spider gears. The red stuff is grease to hold everyting together
Here it is fully installed.
Installed an Non-ABS 80 series master cylinder. I had to remove the proportioning valve and cut and flare the existing lines. I may have to plumb an adjustable proportioning valve to compensate for the rears. We shall see once the larger tires, cage, and armor are on the vehicle.
so what is the advantage of the 80 master other than a 40 hydraulic one?
The stock master cylinder was designed for disc front and drum rear brakes. When you convert to 4 wheel disc you want a master with a larger bore to push more volume of fluid to the caliper pistons. There are other alternatives but I chose this path. Some may argue it isn't needed, but I wanted to eliminate any doubt in the system. I have had cruiserheads that switched to 4 wheel disc using the stock master cylinder with no issues...and some that had major issues until they swapped the master. Clear as mud?
sounds like a pretty ambitious plan! looking forward to seeing the progression and the finished product.
Good luck
bull said:
overkill rotors and monte carlo brakes. It is what the kit came with...
Your going to hate those rotors.
The holes will fill with mud and rocks. Same things for the groves. Slotted and drilled rotors should only be used on road only. Unless your going for a rock climber only.
Did you put in the locker before installing the 4.88 gears?
Can OEM power steering work with a spring over?
Oem power steering can work with a spring over, but I don't think you will be too impressed running over sized tires. The oem power steering just doesn't handle heavy meats that well. I had factory power steering and I ended up changing to saginaw.
Hey Bull, cruiser looks nice! So your up in Sammamish? I remember when it was still Redmond (or the Plauteau), I'm an EHS grad....1999! Anyway, not to hijack the thread, but when is the next cruiser head meeting? I bought mine a few weeks ago and would like to check it out, I live over in the Green Lake area in Seattle. I heard the meetings or over in Phinney Ridge?
Bull, sound like a sweet build up, you're doing a lot of modifications to your 79 that I'll eventually get around to; I look forward to seeing the finished Cruiser.
