OK folks, I know you have all been patiently awaiting the results of the chase for the vibration, so here goes.
It all started many moons ago with a lift. I chose the medium lift because I didn’t have a bull bar/winch and wasn’t sure when I would get one, I also don’t carry a lot of loads, don’t have a rear heavy duty bumper and wasn’t sure when I would get one of those either. The medium lift sounded perfect for me. I assume I got the medium springs as Christo has asked me to check the box to be sure, unfortunately I shipped my stock springs in the OME boxes to Lowtiderider for his 60 suspension project, so I was unable to confirm that I did get the medium lift. I did not get an alignment before the lift. After the install of the lift I waited a month so the springs could settle out and took it to Toyota to get an alignment check. With the OME CC bushings in place my castor measured 0 to 1.2 degrees. With the addition of 33 inch Truxus MTR tires she liked to wander the road like a dirty hooker. Note at this time I don’t recall a grrrrrr at all, just a wandering truck. So with a little searching on the mud board I decided to install the castor plates that slee sells. They are a very high quality product. I installed the plates and then two days later drove to the beach (5 hour drive) it tracked much better. I still noticed I had a little stink bug look so for the fun of it I put the Mr. Gasket 1 inch spacers in front. Now the truck sat perfectly level and looked good. Over the following few weeks I started taking Real Estate classes across town and had a highway drive of about 30 miles round trip. I started noticing a vibration coming from what felt like the front end. When I got home I crawled under the truck and noticed the tie rod was sitting on the control arms. Seemed that the vibration got worse and worse, and I could make it come and go with a feathering of the gas pedal. I tested things out by removing the front drive shaft, locking the center diff. and driving around with no vibration. So I figured I had it wooped, it was the front shaft. I put new Ujoints in and put the shaft back in. Vibration was still there. Next I grinded the arms to get the tie rod off the control arms. Took it for a drive with the front shaft in and still had vibrations. Next attempt at a fix was a know-it-all at a driveshaft shop that said my driveshaft was too long and was bottoming out. I still to this day have no idea why I was naive enough to listen to him and pay him to shorten my front shaft. That obviously didn’t fix the vibration either.
Scratching my head and posting on the mud board brought about the discussion of pinion angles and double cardan drive shafts. It appeared that I was a perfect candidate for a double cardan shaft. I really wanted to purchase the shaft from slee since he had given advice on the phone and posted in the threads about this issue, but the price was just too high for my wallet so I had one built here in town for a lot cheaper, sorry Christo. Now things begin to get interesting. I drove around for two weeks with the front shaft out with no grrrrr to speak of. NOW, two days before I picked up my front double cardan drive shaft I drove a good ways on the highway, I noticed a slight grrrrr. What the heck is that I thought. No way! Was I feeling some of the grrr from the rear shaft now? I was really getting frustrated and confused. I picked up my front DC shaft and installed it. Grrr was still there! Man was I pissed off.
Yesterday I drove around with the rear shaft out and the center diff lock locked. Smooth as silk. So there is no issues with the double cardan shaft, all in all I guess that was a good move. I’m guessing that my next move is this: new ujoints in the rear shaft and adjustable upper links to move my pinion down a little. That’s the last thing I can think of to fix this. If that doesn’t work I will sell the truck and buy a jeep.. . . . . . .just kidding. I will sell my lift and get a 6 inch lift!
I don’t know if this helps anyone, but perhaps others tracking down driveline vibrations may learn something from my story. I hope that others can pinpoint the vibration quicker and not throw as much time and money at it as I have.
One thing positive I look at in this entire situation is my education. I have really learned a ton from this experience and feel that I can use this knowledge in the future when tracking down driveline issues or designing 3 and 4 link suspensions.
EDIT: Thought i should try to bring this thread full circle. . . . anyways, grrrrr is gone. Cure ended up being a combination of rear ujoints and, some how, the driveshaft had been installed 1/2 in-phase and 1/2 out-of-phase. Hope that makes sense and helps. As of today (12/7/05) i have not removed the new DC front shaft and replaced with OEM shaft yet to see if there was in fact vibration coming from the front.
Leason learned from this is if you are having driveline issues, and you feel like it's coming from the front, don't count the rear driveshaft out. That could in fact be the problem. When testing for driveline grrrrr, be sure to remove BOTH front and rear shafts, one by one and inspect them closely in order to track down the vibration.
