engine colors?
wenatchee
I'm planning on pulling my motor this next weekend and I would like to paint it but i cant pick a color to go with. what color where the blocks when they where made or did they even get painted? I just got the head back from the machine shop and they painted it this silver color and it looks really good so I dont know if I should just paint the block the same color or not. if anyone has painted there motor and has pics I would love to see them? any does and donts that I should know about? the reason I'm pulling the motor is to rebuild it. should I use some kind of loctight? if so what color? thanks
I don't know what the color should be, but I think factory was black. I chose to paint mine "cast iron" gray. Black on the side cover and oilpan. I think leaks are difficult to trace on an all black motor. JMO
Ed
Ed
nice before and after oil cooler pics :flipoff2:
What????....we gotta time sequence every pic now?!?!?!?!
Latest would show a "Big Cap" side cover.
Poser is putting together a 4 speed and 4:1 Orion for me and when that arrives I'll tear it down again. That way I can really Web-Crawl. Cyber-Wheeler that I am.
BTW, Brian, the Mennonite Relief Sale here this weekend raised 30K net.
Ed
Max, quit screwing around and get a 2F valve cover! They don't LEAK!
But I dig the bleu!
Ed
The "hide-a-leak" issue with black is true. Still it looks good.
I painted mine cast iron grey but it's a LOT darker than eds. Block is grey with all accessories semi gloss black. Looks pretty slick. I'd post pics but I'm not at home. BTW, Both above motors look good.
I had the front end sheet metal off and was able to power wash it after degreasing. Worked pretty good. Then I broke out the wire wheel and scraper. After that I cleaned by hand with a towel and simple green. Lotta work but came out nicely. I used engine enamel which has the hardener (clearcote) in it. If you use a clearcote thats not rated for high temps you can run into problems. Especially on exhaust components.
B6i6K6e6R6b6O6y said:
you guys have some nice looking motors. how did you guys go about cleaning your motors? what about primer and clear coat?
Mine just came back from the machine shop and was "peened" with shot after it was heated to 600* and it looked like a new casting. I wiped it down with lacquer thinner and shot it with PlastiKote "cast iron" gray which is good to 600* and resists most fluids. They make a clear hi-temp engine enamel which I should have used on top of that. You can see where I did use it on the T-stat housing over the gray.
Ed
