dash pad removal - trick?
DSRTRDR
I can mangle anything ...
Baton Rouge, LA and Fountain Hills, AZ
now, I got all the screws and knobs loose, is there some snap mechanism to get the dash pad off - I don't want to rip it to pieces, it's cracked enough as it were. What's the trick? Thanks, Claudia
On mine there were clips on the back that were stuck. Lay down the windshield to get a better look.
Take a look at the picture #99 is under the dash pad with little slits in it. #13 is screwed into the dash pad and has flat prongs which slide into the slits. If you pull the dash pad up and back it will come off. I just covered it with a hard cover and no need to remove it, unless you paint underneath like I did.
$OR part number 172-40 $64.00. Works great and looks like new.
Les
thanks for the tips, got it off. I want to put the cover on and according to other posts here it glues on nicer when off the cowl. Plus, I found mounds of dirt underneath; can't harm to clean it off.
holy thread revival batman :eek:
and for the record, I would not get the cheapo glue-on cover again - it's held up well that past 8 years and I am not taking it off now, so it got that going for it
but it did not fit properly at the sides, and everytime I open the door and see that spot, it irks me :rolleyes: I know, first world problems :rolleyes:
