SOA Driveshafts: Choices and Options
Long Island, NY
Now that the SOA is coming to a close:
1. Double Cardan
2. CV
3. Stock
4. Combo
I am looking for the best application. Rear is at 22 degrees (pinion) and the front is 14 degrees.
I have 'heard' that a double cardan on the t-case side and a standard u-joint on the diff side for each shaft is the way to go.
1. Is every vehicle different (I need to measure to be sure) when it comes to re-sizing the lengths of the driveshafts?
2. Depending on what the best scenario/combination is - where are these available, meaning, what vehicles had them, etc..
3. How are they built/setup? Will the driveline shop know?
Technical links told me that double cardan and/or cv type driveshafts from a minitruck or early 60 work, but I would like to put together a more accurate/detailed document for the technical links.
Any information is greatly appreciated.
ragman
you really only have two options up there.
CV (double cardan) on one end and stock on the other
Or just stock
If the pinion points directly at the Tcase then you want a double cardan (CV) at the tcase end.
If the pinion flange is parallel to the Tcase flange then you want conventional U joints.
1. for the most part every vehicle is different. Using the lengths that someone else gave you is a good way to end up have a ds that is either too long or too short.
2. Minitruck fromt CV's or FJ60 front CV's work very well for this. All of them can be adjusted to have a pretty good operating angle by Jess at high angle.
3. Any driveline shop should know how to assemble a CV unit. Personaly I reccomend Jess at www.highangledriveline.com
He Really knows his s***..
You are making this a lot more complicated than it is.
Or just stock
QUOTE]
Why is this? Wouldn't a stock driveshaft work for this also?
Every vehicle is going to be different. Did you flip springs or not, springs used, SR or not, added crawl box, see?
I am running a 85 minitruck CV on my rear due to my driveshaft being only 21" this is a must for me. On the front I am running the stock cruiser shaft lengthened because I am running a toybox.
You need to set the weight of the truck on the axles then start measuring angles and length. The driveshafts were some of the last things I did.
Will it work?
Yes it will I ran my truck that way for a very long time.
However, it will cause vibrations. Wether you can feel the vibrations over swamper whine is another thing..
Dallas, I am Running a Stock Rear shaft.. Works Great at all speeds.. Front Shaft has Stock Joints with Square Tube for the slip part.. Works ok up to 20MPH But less than desireble.. I need to come out some time this week!!
If your 3rd points directly at the T-case you should use a CV.. I have some Laying around the house that may work for you..
Trollhole said:
I'm sorry I was talking about the front DS.
inthe front it is not as big of a deal. So a stock shaft is a bit easier to use.
But you will still see the vibrations while driving at speed.
1. Double Cardan
2. CV
3. Stock
4. Combo
ragman
#1 yes
#2 I used two front driveshafts from an 83-84 FJ60 that have the OE DC joint. I have been told the front d-shaft of the solid axle minitrucks can be used but will need the holes enlarged for the larger 11 mm bolts.
#3 My d-shaft shop gave me the deer in the headlights look when I told them I wanted a double cardan. I guess that term is Toyota specific...the American/Dana people call them a CV. But this still left them staring as they said they had no way of adapting the Dana parts to my bolt pattern required on the TC. I have since learned people sell this adapter, but it ain't cheap.
The place I dealt with does primarily big rig stuff...guess they don't see to many different setups, and certainly no 20-30 year old Toyota stuff. On the other end of the spectrum there are other shops that deal in custom stuff like Tom Woods and High Angle Drive Line that come to mind. Get your wallet warmed up....
Regarding other usefull information, I would rotate the pinions up to wthin 2-4*of the d-shaft angle. When the suspension compresses the angle will lessen. You want this angle near zero as the DC will cancel itself out. Different angles = different amounts of 'travel' by the caps and will result in a two sine waves that do not cancel each other and subsequant vibration.
Try these for info...
http://tinyurl.com/9d6z4
http://www.rockforddriveline.com/toyota.pdf
http://www.4xshaft.com/index.html
http://www.highangledriveline.com/
http://www.4x4wire.com/toyota/tech/cvmod/
I run a mini CV grafted to my stock rear shaft - cheapest option and I haven't needed increased slip travel. On the front end with shackle reversal - needed longer slip, just retubed my stock shaft but it comes apart once in a while. With new output and pinion flanges you can run Chevy joints and have an all new custom long travel shaft made by any shop for around $150. Need to call Kurt this week about output flange...thanks for the reminder.
