Build FZJ80 + Taco 6 speed + Orion
Stamford, VT North Adams, MA
Well, things are getting out of hand with the latest project, so I figure it is about time to move it on over here to Hardcore.
For those that don't read the 80 section, have a look here for the beginings of this project.
https://forum.ih8mud.com/showthread.php?t=47895
I'm working on installing a Aisin RA60 6 speed Tacoma manual transmission behing my soon to be built 4.6L 1FZ. After weeks of deliberation on what to do in order to get a proper low range, it has been decided that the AA Orion 4.00 - 1 transfer case kit is the way to go.
In order to get the Orion to fit the 19 spline RA60 output shaft, the gear will have the center milled out, splined, and then be press fitted to a large splined adapter. This adapter is actually a piece from the stock HF2AV transfer case... it will be machined in various ways to accept bearings, seals, and the gear.
Pictures soon.
Why not just do an atlas?
Woody answered the first part, keeping the stock offset axles. The gas tank would need to modding, too.
Pics of "stuff"... Orion is on the way.
Transmission sans tail housing, note the nice long 19 spline output.
This is the input/main shaft from the HF2AV partially slipped onto the output. The input gear is press fit on here, the shaft is roughly 1 7/8" diameter and 44 spline. If anything has a chance of holding a custom splined gear, this shaft does.
Here are the input gears, counter clockwise from top left 16 spline 77' case, 19 spline 87' split case, 44 spline 93' HF2AV.
So does this mean there will be no more updates in 80's tech?
Not that big of a deal since I frequently come in here to look around and drool but alot of the fella's will be missing out.
I can update the 80's section... Just figured with all the mods required to fit this combo, it is way beyond bolt in, thus fewer folks will be interested there.
euclid said:
Or for anyone who want to drive over obstacles very smoothly without spining a tire or burning up a clutch. :flipoff2:
No burny burny with 4.17 x 4.00 x 4.88... only old lazy people with automatics worry about spinning tires anyway. :flipoff2: In all seriousness, automatics do an excellent job in some situations.
I made a smidge on the last rig, plus I got to wheel it for 2 years.... No 80 for you! :D
Brian,
Keep the posts coming. Very interesting idea. Look forward to watching it come together. :beer:
Very sweet. I'll be trying to figure out how to mount a LC split transfercase behind a HiLux/Surf (4Runner) auto tranny. I am thinking about a Marlin Crawler toybox with the front built to adapt to the HiLux slushbox and the rear made to adapt to the split TC. With the toybox in place, my crawl options would be amazing.
(Side note: my project involves pulling the H diesel drivetrain out of my HJ-45 and installing a 1KZ-TE turbodiesel/slushbox pulled from a JDM half-cut. I want to keep my LC offset full-float rear axle and end up with a KZJ-45.)
