HELP? Trouble starting
West of the Pecos
SOMETIMES, not always, when I stick the key in the ignition and turn it, I get a "click" and that's it. SOMETIMES, the engine starts to turn over and then stops. The "click" sounds like it's coming from somewhere near the distributor, but my hearing isn't great, so I can't quite pinpoint it.
This problem ONLY happens when the engine is cold. Not cold as in weather, but cold as in the truck hasn't been run since the previous day. After you get it started and run it a while, it starts up fine. Next morning, it's a crap shoot whether it'll crank up on the first turn of the key, or the 20th.
Any hints on where to start looking for the problem?
thanks.
Sounds like a bad battery or connections. I'd start with the battery.
Battery is only a year and a half old and connections are tight and clean. That was the first place I looked.
Well then tell me what you already checked and we'll go from there.
If you're positive about the battery (they can fail in a short time) then you may need to rebuild your starter. I would check the connections first.
The only thing I did was try to wiggle the cables where they were connected to the terminals. They are plenty tight and show no corrosion. I did NOT check the ground wire... yet.
This problem has been ongoing. First time I noticed it was maybe 6 months ago, but I figured since it always ended up starting after 3 or 4 tries and I didn't want to spend a bunch of money having a shop try to track down the problem, I'd just live with it. Yesterday it took 15-20 minutes and maybe 50 turns of the key to get it to fire up, so I don't want to live with it anymore.
If I disconnect the battery cables, clean the terminals, put some grease on them, and then reconnect them, is there anything I need to do to "reset" the system? I know some vehicles have alarm systems or onboard computers that have to be reset somehow after you disconnect/reconnect the battery.
Could be starter contacts, ignition switch or neutral start switch.
When you're in a "no start" situation, while holding the key in the START position, try wiggling the transmission shifter. If no luck, try the same thing but shift into neutral first. If this seems to be the culprit, then replace the neutral start switch.
Try holding the key to the START position and slowly rock the key back and forth in the ignition switch.
If still no love then rebuild the starter.
Thanks guys! I'll tinker with it tonight or tomorrow and report back on what (if anything) I can figure out.
Well, the goofy thing has started up perfectly every time since I started this thread! :rolleyes:
I'm going to go ahead and order a set of starter contacts from CDan and see if that fixes it.
Thanks again!
