About two months ago a buddy of mine, also an experienced mechanic, adjusted the valves while running. That's just the way he's always done it.
Well, last night I got a wild hair up my a__ and decided to check them with motor not running. Some were right on and some not. There were 3 that were way too tight and I could not get any clearance whatsoever. That freaked me out a bit, but I did what I could and ran it for a few minutes to warm up again and readjusted the valves. The valves with zero clearance were now able to be adjusted--I guess something was just stuck.
The end result of the report is more than anything else, just the way it sounds, I did not check and record the pre-adjustment clearances. The valves talk back slightly more at idle. Since the rebuild there has always been more valve noise than usual around 2000rpm, especially when cold. This noise is still there, but now it is not as noticeable.
Adjusting the valves is a relatively simple job, especially with the valve adjustment guide from JC in the technical links.
